- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
HELP Isspro gauge problems?
I am in the middle of installing my three Isspro gauges and have run into a problem. I am using the diesel manor install instructions, but I can't seem to figure out how to run the trans temp sensor wiring down to the tranny because it is to short. If I use the hole in the firewall that the instructions show there is no way that the wiring for the sending unit will reach. So what do I have to do? I would just solder on an extension of wire but where the wires connect to the little junction box thing the screws have been super glued so you can't easily remove them. So does anyone have any ideas??
Thanks, Mike |
| Sponsored Links |
The screws to the box are just covered with a sillacone, it will work right off when you poke at it with a screwdriver. Follow where the auto tranny cable goes thru the floor and run it right there. It should be long enough to not have to mess with. I have done 10-20 installs that way. Same thing for your pyro probe, follow that shift cable and poke thru the grommet there. |
Thanks guys. I went ahead and called Diesel Manor and their tech guy said I could extend the wires myself so that is all I did. I was going to run the wire through the shifter cable grommet but it still didn't seem like it would reach so I just cut and soldered extension wires on. Thanks for the fast responses guys.
Mike |
| Sponsored Links |
