Has Anybody used a Fuel sump from xdp - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-10-2013, 05:48 PM Thread Starter
Dieselboy144's Avatar
I'm getting an air dog and don't want to drop the tank if I don't have to. I was wondering if anybody has used the fuel sump from xdp. Is it worth the money or just better to drop the tank and do it that way? Any help is greatly appreciated.
Dieselboy144 is offline
post #2 of 11 Old 10-10-2013, 06:38 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Don't get the air dog. They are crap. Many many people have had their pumps leave them stranded. Id go with a aeromotive a1000 pump, get the strictly diesel pre and post pump filter kits. Regulated return.
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 11 Old 10-10-2013, 06:48 PM
CSIPSD's Avatar
Not a fan of sumps... Not one bit.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 11 Old 10-10-2013, 06:58 PM Thread Starter
What is it that you dont like. do they leak? plug up?
post #5 of 11 Old 10-10-2013, 07:00 PM
CSIPSD's Avatar
Cutting a hole in a perfectly good tank.
No benifits over a 5/8" pickup.
Easy to damage.
Prone to leaks.
Not legal in many states.
Expensive to replace your tank later on...
There is nothing really to like.
Joe
CSIPSD is offline
post #6 of 11 Old 10-10-2013, 07:17 PM
6 L chevy eater's Avatar
I have to say I love the sump. If you think about your pump being fed threw a sump is being gravity fed. The pump dosent have to work no where near as hard to pull the fuel up and out out of the tank threw a pick up tube.And with pick up tube you may end up havin the 1/4 tank issue. I'd say a sump is def worth the money. I have and xdp sump in my truck and it does great. And for lift pump I run a fass 200gph . Got a good deal on it
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #7 of 11 Old 10-10-2013, 07:19 PM
CSIPSD's Avatar
Every sucked a hose out of a tank, then let it lay on the ground... does it stop flowing or does it keep on kicking?
Remove the fuel line from the back of the pump on a factory set up and tell me if you dont get a bath...
Joe
CSIPSD is offline
post #8 of 11 Old 10-10-2013, 07:24 PM
Just my opinion. Don't get ur party's n a bunch.
2004 F250 ccsb
post #9 of 11 Old 10-10-2013, 07:25 PM
CSIPSD's Avatar
I'm simply pointing out the flawed logic...
Daily driven street truck, dont do it.
Joe
CSIPSD is offline
post #10 of 11 Old 10-10-2013, 07:28 PM
You may be correct. But that's my logic. And with the sump you don't have to worry with the pump losing prime when fuel tank gets 1/4 tank and fuel is sloshing all around the pick up tube
2004 F250 ccsb
