Stage 2 swamps injectors. Now what? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-07-2013, 10:01 AM Thread Starter
johndeeregarner's Avatar
The stock injectors on my 99.5 took a crap about a week ago. I bought a set of swamps stage 2 160/100 injectors and am thinking on ordering a boost fooler and BD Wastegate actuator. Anything else/better to do while I have it semi-taken apart? I was thinking on ordering an ATS compressor housing in a few months and a set of gauges shortly.
johndeeregarner is offline
post #2 of 13 Old 10-07-2013, 12:20 PM
Quoted: 31 Post(s)
Gauges should be put in before your new injectors. New injectors without a bigger turbo will = a lot higher EGT's. You need to monitor that at the least. I would also recommend a tranny temp gauge and Boost Gauge.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #3 of 13 Old 10-07-2013, 12:35 PM Thread Starter
Ok. I'll go ahead and get a set of gauges.
With that size injectors, would a larger turbo be better than upgrading the stock?
post #4 of 13 Old 10-07-2013, 02:00 PM
ja_cain's Avatar
You should definitely upgrade the turbo with those injectors in order to experience their full potential. 38r or SD66 would be a good choice if you want to stay with the factory mount.
2002 F-350 SCLB PSD 4X4 6 Speed
ja_cain is offline
post #5 of 13 Old 10-07-2013, 03:30 PM
blue99stroker's Avatar
Quoted: 282 Post(s)
38r is a must. the stock turbo is almost at its limits with stock injectors honestly.
if you cant afford a new turbo yet, get the injectors slightly detuned and look into a ww2 or a similar billet wheel.
also if your fuel system is stock, atleast get the fuel rail crossover from riffraff.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #6 of 13 Old 10-07-2013, 04:11 PM Thread Starter
What is the difference in the stock turbo and the 38r? Does anyone have any experience with the ATS compressor housing? I've done some research on aftermarket wheels and from what I've seen, the stock wheel is just as good as the aftermarket ones. So I'll probably stay away from upgrading the compressor wheel.
post #7 of 13 Old 10-07-2013, 05:08 PM
ja_cain's Avatar
The 38r is a ball bearing turbo whereas the 38 is a journal bearing turbo. The 38r is not rebuildable but the stock one is. The 38r will spool much faster and should be good to 450 to 500hp. Also, some say that the 38r can be noisy to the point of being annoying after a while. I have yet to hear one so I can't really comment on that. I heard that there is a billet wheel that supposedly quiets these turbos down some. The other turbo to look at is an SD66 which is a hybrid of the stock, 38r and van turbo I think. It retains the rebuildability of the stocker and can support even more hp than the 38r due to the larger exhaust housing (I think). This is the turbo I will probably go with (or some variation of it). Hope this helps.
JC
ja_cain is offline
post #8 of 13 Old 10-09-2013, 04:19 PM
Joel's Avatar
Quoted: 10 Post(s)
JC
Some of that is correct
The more relevant difference in the 38R is that the compressor wheel is larger allowing more air flow.
You can put a larger exhaust housing on any of the turbos in question to keep drive pressures down.
OP, do you have tuning lined up to run the single shot injectors already? And yes gauges is #1 priority
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #9 of 13 Old 10-09-2013, 04:26 PM
ja_cain's Avatar
That's right. 38r is 66mm on compressor side. That is why I like the idea if the sd66 because it has the 66mm compressor wheel, journal bearings and larger exhaust housing.
Sent from AutoGuide.com App
ja_cain is offline
post #10 of 13 Old 10-09-2013, 08:04 PM
Quoted: 282 Post(s)
the stock turbo wont last last long with stage 2's.
its not if but when it blows up.
and the billet wheels are a huge improvement over the stock compressor wheel.
