Should I swap the camshaft or no - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-03-2013, 10:11 AM Thread Starter
Dieselboy144's Avatar
I recently bought comp 910-16 springs with .030 shims. I was wondering if I need to change the camshaft or if I will be ok to run on a stock 1. I have a 00 7.3. Just bought swamps 250/200 injectors and there hvhf idm to go with it.
supporting mods are
t-500 hpop
bills custom intake and s&b filter,
Riffraff Billet Wheel
John Woods Tow Master Trans
Cryofrozen flexplate
Bellowed Up Pipes.
ARP Head Studs.
Hydra Chip from PHP
4 inch straight pipe to 7 inch twin stacks
Im looking to get 550-600 hp
Any Help/Advice is greatly appreciated.
Dieselboy144 is offline
post #2 of 4 Old 10-03-2013, 12:25 PM
the1laf's Avatar
If you were building a motor from the ground up I'd put in a different cam but if it's still in the truck I wouldn't worry about it too much. lots of trucks are still running the stock cam, maybe talk to Matt @ Gearhead if you're really worried, he makes cams for the 7.3.
Assuming you didn't mention turbo size you're going to need a bigger turbo, the GTP38 and 38R won't support your goals.
Look along the lines of H2e, S468 etc.
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #3 of 4 Old 10-03-2013, 12:33 PM Thread Starter
Originally Posted by the1laf View Post
If you were building a motor from the ground up I'd put in a different cam but if it's still in the truck I wouldn't worry about it too much, maybe talk to Matt @ Gearhead, he makes cams.
I was looking at getting a 66/74/.91 box charger with the t4 flange and up pipes.
post #4 of 4 Old 10-04-2013, 06:41 AM
Thuglike's Avatar
You DO NOT need a cam.
the stocker is actually a real good one!!!!! Plenty of guys around 600 on the stocker.
Thuglike is offline
