looking at ordering a phoenix from PHP and have some questions - Ford Powerstroke Diesel Forum
post #1 of 21 Old 10-02-2013, 07:20 PM Thread Starter
I know you have to clean the computer connection and clean silicone off of it. after I do this will it cause any issues later if I remove the Chip?
Next what settings should I go with? the truck is a 2000 f250 crewcab shortbed 2 wheels drive automatic . I plan on leaving the truck pretty much stock. I might add a better air intake and possibly delete the stock muffler maybe. The truck is a low mileage truck with only 96k miles.
I would like to pick up some performance and I don't like how the transmission seems to shift too early. A few more MPGs would be nice also. the only towing I do with the truck is my race truck on an open 18 ft car hauler. The race truck weighs about 2900lbs not sure about the trailor.
These are the settings Im thinking about going with
1) Stock (I guess I need the stock setting Not sure what do you guys think?)
2) whisper (Im between whisper and High Idle)
3) 25hp tow
4) 65hp tow
5) 80hp daily
6) 120hp race
2005 f250 extcab long bed 6.0 torqe shift (SOLD !!!)
2000 f250 7.3 powerstroke automatic ccsb virgin
05powerstroker is offline
post #2 of 21 Old 10-02-2013, 08:33 PM
Gaius's Avatar
Quoted: 43 Post(s)
I wouldn't worry about a stock tune. I'd also ditch the 25hp tow since your load is light. I hear the whisper tune is pretty useless, but I'm guessing you don't need the high idle in Houston...
I'd also get the 100 performance in there, the race tune is sort of on/off and not fun to drive very often.
Been thinking of getting a PHP chip to try their tunes. I have a different tuner but have: High idle, Economy (rarely use), Daily Driver, Sport, Tow, and Extreme
I use daily driver almost 100% of the time, and high idle on cold mornings (below freezing).
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #3 of 21 Old 10-02-2013, 10:36 PM
Quoted: 14 Post(s)
I usually run my truck in 120hp race mode. I don't notice any drivability issues at all. Startles people how fast an 8k pound truck can move.
ttyR2 is offline
post #4 of 21 Old 10-03-2013, 05:49 AM
hansel's Avatar
Quoted: 97 Post(s)
If you can swing the extra cash, I'd upgrade too the Hydra chip. But some other things you should also get are some gauges, and since you are towing change your transmission cooler with the 6.0L one, then get a good air intake system (NOT K&N) ditch the stock exhaust and get a 4" system, that will help get the air in and out. With the Hydra chip you plug in your laptop and pick the tunes you want, but if you can't I'd drop the whisper and the 25hp tow tune and replace them with 100hp performance, and maybe the 140hp extreme.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #5 of 21 Old 10-03-2013, 05:58 AM
Jerrybizzle's Avatar
Quoted: 24 Post(s)
The 65 tow tune should be the only tow tune you need. I like the 120 race tune as well. Only downside is it doesn't shift to od till about 48. I just had mine reburnt to stock, 40 tow, 65 tow, 80 daily drive, 120 race and whisper. I haven't been able to try the whisper tune yet. In process of resealing my fuel bowl and snapped my FPR cap. Have to get a new one today.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #6 of 21 Old 10-03-2013, 08:04 AM
Gaius's Avatar
Quoted: 43 Post(s)
The PHP race tune doesn't have a touchy pedal? My Wildman tune is crazy, seems to be WOT within 1/4-1/2 inch.
05 F350 Crewcab
Gaius is offline
post #7 of 21 Old 10-03-2013, 08:18 AM
Quoted: 27 Post(s)
This is part of the reason people really like PHP. Feels like a stock truck until you really get into it.
Dont get me wrong, it has great throttle response but its not a touchy feel.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #8 of 21 Old 10-03-2013, 05:37 PM
hansel's Avatar
Quoted: 97 Post(s)
No, its not touchy at all. It feels like stock pedal but with alot more power
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #9 of 21 Old 10-03-2013, 07:57 PM
Quoted: 14 Post(s)
Yep...feels stock till you get into it hard. They did an excellent job with the tunes. Nicely refined.
ttyR2 is offline
post #10 of 21 Old 10-04-2013, 05:40 AM Thread Starter
How hard is the 140hp extreme tune on the transmission, motor and turbo? I think for me the 120 would be plenty. I hate adding the gauges because I like to keep the inside of the truck looking stock. I thought about getting the edge tuner that had the gauges on it. I hate the way gauges look on the pillar.
As far as towing I used a gas 1/2 ton truck to tow what I tow for years now. Its flat here also no hills. I could buy the hydra but I just really don't plan of doing much with this diesel truck. I was going to just buy a hand held tuner but I heard their transmission tuning sucks. That's the main reason I am now looking at the PHP chips. I don't want to have issue with the transmission and don't want to be working on the truck all the time. LOL when this truck goes to the race track its because its towing my race car. I just want it to be a little more fun to drive. right now it won't get out of its own way.
