- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Wastegate Line
I got my gauges installed so i decided to play with it. I made 2 runs on a stretch of road, one with the line plugged in and one unplugged, but the time was the same for both runs. When the line is plugged in i can get about 15 psi, with it unplugged i get about 22. My guess is that with factory programming, it doesn't dump enough fuel to make use of the extra boost
. Also i notice when building boost for the launch, i had about 2 less psi with it unplugged. Also, what are the pros and cons with hooked vs. unhooked?
| Sponsored Links |
I ran my truck with and without the wastegate tube connected. Hooked up I got 17 PSI. Plugged I got 23 PSI. No gauges yet. I was checking mine with a scanner hooked up to my laptop. I put it on the dyno last weekend and did the same test. Higher boost resulted in the truck defueling at a lower horsepower. Lesson learned: Get a fooler of some sort or you're wasting the extra boost gained. (No pun intended.) Wheels/tires are stacked in the driveway. Sig below shows the new shoes! Hank Last edited by Hank : 06-29-2008 at 06:46 PM. |
More boost does not mean more power, and your tests once agian prove that. Especially if the truck isn't smoking at all. At 22-23 psi of boost I highly doubt the fuel is beind cut back. If you have a scanner hooked up you can see what the mass fuel desired is and that will tell you if it's cutting fuel back.
Trying to make to much boost by unhooking the wastegate can and will decrease power once you get out of the turbo's efficienty range. It starts heating the air more than it's flowing more air and can actually flow less mass of air at a higher psi being it's to much hotter. Southpaw if your PCM is seeing enough boost to set a code then it's most likely defueling as well. You may need to put a different value diode in your grounded wire to prevent the code from being set. |
| Sponsored Links |
