tuner question - Ford Powerstroke Diesel Forum
post #1 of 19 Old 10-01-2013, 07:16 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
tuner question
My friend has a 1999 F-350 dually 7.3 2X4. He wants to get a tuner for better mpg's and a little more power. I don't know anything about the 7.3. What are his options? Which is the best tuner for he 7.3? Any input is appreciated guys.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #2 of 19 Old 10-01-2013, 07:54 AM
Powerstroke_21's Avatar
well you can get any of the canned tuners, but there aren't very many people that like them and prefer custom tuning using a ts 6 pos switch. with that you can go with tuning from tony wildman, matt at gearhead, swamps, or beans to name a few. For what it's worth, I'm going with gearhead in the next couple of days. THe custom tunes are awesome because they are tunes that are specific to your truck and they are the exact tunes that you want
Edit: so if i would say anything, I would tell him to go with a ts 6 pos switch with custom tuning from any of the ones that I listed. They all have awesome reviews and I haven't heard anything bad about any of them
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #3 of 19 Old 10-01-2013, 07:59 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
Good info thanks. So can he get the 6 position chip with canned tuning until he gets custom tunes or if he goes with the 6 position chip does he have to get custom tuning right away?
08 F350 cc/sb 4X4
post #4 of 19 Old 10-01-2013, 08:04 AM
he doesn't have to get custom tuning right away he can get the tunes that come right from ts which, i believe, are Stock, High Idle, 50hp, 75hp, 100hp, 140+ Extreme and those are the canned tunes that come with every ts 6 pos switch if you get it from xdp or alligator performance, but if he does that and decides he wants custom tuning usually tuners charge around $200 to reburn it and put their tunes on it. and custom tuning from the get go is around $400
Edit: and FWIW I wouldn't go with a smoke tune as they will harm a diesel engine over time
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #5 of 19 Old 10-01-2013, 08:07 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
Oh ok. I was looking at the tuner from Rudy's diesel. I am not sure which tunes that comes with. How hard is it to install? Is it fairly simple?
08 F350 cc/sb 4X4
post #6 of 19 Old 10-01-2013, 08:10 AM
I haven't heard of them, but if it's custom tuning you can usually pick what tunes what you get, if its just the tunes that come from ts you get what you get (the tunes i listed earlier) and idk how hard it is to install because I haven't installed one yet (it will be my first time with a tuner) but they usually give you instructions and from what i've heard its not hard at all
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #7 of 19 Old 10-01-2013, 08:12 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yea I believe those were the tunes it listed on Rudy's website. I really appreciate all the info bud!
08 F350 cc/sb 4X4
post #8 of 19 Old 10-01-2013, 08:13 AM
yup no problem!
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #9 of 19 Old 10-01-2013, 01:29 PM
Jerrybizzle's Avatar
Quoted: 23 Post(s)
Slight misinformation above, but not too far off. The php Phoenix six position chip which utilizes the base ts 6 pos switch with their custom tunes is 300. You can get base ts chip for just under 300, like 298. I have the php which doesn't hardly smoke at all, very minimal as it is tuned to my specific PCM code. A friend of mine just got the base ts chip and it smokes like a son of a gun. If you want cheap custom tunes, get the Phoenix. Or get ts base for same price and pay an extra 200 later for custom burns from reputable tuner (php, beans, swamps and others). Or for 425 look into php hydra which loads tunes from several tuners.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #10 of 19 Old 10-01-2013, 01:33 PM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
So is this the one he would need? If not where would he get the Phoenix one?
TS Performance 7.3 Ford 6 Position Chip
08 F350 cc/sb 4X4
