Modified fuel lines - Ford Powerstroke Diesel Forum
post #1 of 25 Old 09-26-2013, 11:32 AM Thread Starter
Quoted: 890 Post(s)
Feedback Score: 3 reviews
Modified fuel lines
I know the RR systems are a very good system, but instead of putting in return lines for a traditional RR, has anyone ran supply lines to all four corners instead.
That way you still would remove the chance of starvation of the #1 and #8 injectors. Then use a fuel lab PR to adjust.
Now technically this would not be a RR system, it would still be more of a pressure relief system.
Corey@CNCFAB is offline
post #2 of 25 Old 09-26-2013, 11:56 AM
timmyboy76's Avatar
if alone, just reroute the d/s line to the rear port, you'd see a noticable difference in "cackle" noise, to the extent its not even there...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 25 Old 09-26-2013, 12:48 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Id say just do an OBS style E-fuel system. Fuel splits from the pump goes into the back of each head and comes out the front and goes into a FPR then back to the tank. That removes the fuel bowl too really clearing up the valley
Edit: only deletes the fuel bowl if you install inline filters(obviously)
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 25 Old 09-26-2013, 12:52 PM
timmyboy76's Avatar
Correct, thats why i said, plumb d/s line to rear port. Ever hear an OBS "cackle"/tapping sound, from the a/an injector?
post #5 of 25 Old 09-26-2013, 12:58 PM
Chapter Director
Quoted: 5 Post(s)
Idk i dont think ive even heard this "cackle" everyone talks about. Even on my SD and it has the stock fuel system. Is it an obvious sound?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 25 Old 09-26-2013, 03:33 PM Thread Starter
Quoted: 890 Post(s)
Well I emailed Dave at Swamps and he gave me some good info. What the idea can essentially do is create a more budget minded way to supply fuel that does work instead of a higher priced full blown RR. I.E. you can get the stronger spring and save yourself the $150 for a Fuellab PR. Not saying any way shape or form that's its better, just different and that can fix the end of the line starvation issue. Here is Dave's reply.
yes, I have a customer running our 400/400s, twin turbos, etc...that did exactly what you are describing/proposing.
while I can appreciate the theory behind this...we don't believe that it is any better/different than a conventional fuel return system...
ie...all of our (relatively) high power trucks, as well as our engine dyno is setup to run a conventional pump>>heads>>return...and have no problems with injector performance at well over 1000hp.
I'm not saying 'don't be different'...I am just sharing with you, our experience.
take care~
Dave Armstrong
Swamp's Diesel Performance
304-A Sand Hill Rd.
LaVergne, TN 37086
post #7 of 25 Old 09-26-2013, 05:32 PM
Chapter Director
Quoted: 5 Post(s)
But the question is did he tell you that it only works with swamps IDM because all other idms are the same
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 25 Old 09-26-2013, 05:35 PM Thread Starter
Quoted: 890 Post(s)
Lol. Funny. But This is Dave were talking about not Joe.
post #9 of 25 Old 09-27-2013, 08:29 AM
timmyboy76's Avatar
Ramm..i wonder if the "cackle" is more noticable with L99/E00 with all AD injectors. My buddy's 01 has the AE/LL injector in #8, and no "cackle at all or very minuute. While im on D2, my injector bangs away like a "little person" is in there with a ball-ping hammer.
post #10 of 25 Old 09-27-2013, 08:35 AM
Chapter Director
Quoted: 5 Post(s)
Hmm maybe idk. ill have to check my build date but i wanna say its 2/00 but i could be wrong
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
