Well, now what should I do?? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 09-25-2013, 07:00 PM Thread Starter
Started with an 01 7.3 cclb with 4 speed auto. I have taken your advice and done the following mods:
- Complete 5" lift with upgraded shocks
- New up pipes with flexible bellows
- New 4" downpipe and complete diamondeye exhaust
- 6637 filter
- Wicked wheel
- unhooked EBPV, tack welded turbo valve open, removed guts and sealed
- PHP Hydra
- Helo 16s with Nitto Trail 315s
- New moog ball joints and bearings
- EGT, Trans temp and Boost gauges
- 15psi boost fooler mod
- Installed 08 rear diff cover
- Changed oil, diff fluids, hydro boost atf, brake fluid, transfer case atf, etc.
- Working on hutch and harpoon mod tonight
I am disappointed that my mileage has went down so much. Also, the power is not that great. I sold my duramax LBZ with about 400hp and it was amazing. This truck is far from making my smile yet, from a power point of view. I'm also a little worried about the tranny(4eod auto). When I serviced it, there was a half teaspoon of what looked like finger nail clipping size flecks of metal.
What should I do next??
mram10 is offline
post #2 of 19 Old 09-25-2013, 07:40 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
your mileage shouldnt of gone down...
how much boost are you seeing.
you should be somewhere in the 330 hp range
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 19 Old 09-25-2013, 07:50 PM
CSIPSD's Avatar
- 6637 filter
- Wicked wheel
- PHP Hydra
- 15psi boost regulator mod
What did you do that would make you think your mileage would go up?
MPG no no's...
1. Lift- Check
2. Big tires- Check
3. ?15psi regulator mod?
First off remove your "regulator mod" and install one that allows at least 20psi, or your leaving far too much on the table.
You also have a 4R100 trans, not an E4od...
Your mistaken. The OP has turned his truck into a great big brick moving down the road.
Also he would be lucky to dyno 300hp, has really done nothing more then chip it as far as power adding.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 19 Old 09-25-2013, 07:50 PM Thread Starter
I do not have my boost gauge hooked up yet. I will get it hooked up tomorrow and get you a reading.
330hp??? It seems to act like a dog when accelerating. I need to check on my fuel pressure under load too, but I will see how it acts when the hutch and harpoon(not that it matters) mods are done tomorrow.
mram10 is offline
post #5 of 19 Old 09-25-2013, 07:54 PM Thread Starter
This is the boost fooler I was referring to.
DIY Boost Fooler Video by MazdaMartinb4k | Photobucket
mram10 is offline
post #6 of 19 Old 09-25-2013, 08:06 PM
CSIPSD's Avatar
Fuel pressure will not effect hp so long as your filling the injector, 60-72psi...
Joe
CSIPSD is offline
post #7 of 19 Old 09-25-2013, 08:15 PM
Macon's Avatar
Large chunks should never be in your tranny pan. That's not a good sign at all, and you should probably start saving for a new trans.
As for mileage, I agree with CSIPSD. You took a brick, and made it bigger. What numbers were you seeing now, what were you seeing before?
I don't know about 330, but you should definitely be over 300 with just the chip. I'm at 310 on PHP's 65DD tune.
The "Wicked Wheel" likely lowered your max boost, and you shouldn't have gone with it unless you were experiencing turbo surge.
How thick is your smoke trail when you get on it? If it looks like a Cummins, I would venture to say you have a boost or exhaust leak somewhere and that would be a large contributor to unexpected mpg losses.
Gauges are a must. I love my Edge CTS, as I can monitor so many different things in a nice little package. If that's not your thing, you need several gauges, and a good scanner such as AE. The CTS isn't a replacement for a proper scan tool, but it does provide monitors for things you won't get a gauge to do.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #8 of 19 Old 09-25-2013, 08:29 PM Thread Starter
The computer when it was stock, driving it home from oregon, was 19-20. As for now, I get about 13 on the freeway. That seems HORRIBLE to me. I got 7.8 towing a 5k trailer today on the freeway. I guess I better check all the exhaust connections since I just redid the up and down pipes.
mram10 is offline
post #9 of 19 Old 09-25-2013, 10:51 PM
Quoted: 258 Post(s)
i understand that lifting your truck is gonna kill mileage. but i was just looking at other factors, that one is obvious.
their is a ton of factors affecting mileage. so you pretty much have to go down the checklist. boost leaks, fuel pressure, oil pressure are easy to check.
and i agree about the gen 1 ww wicked wheel, when i put one om my truck it killed my top end power, and mileage went down as well. bu i didnt have surge anymore so your better off getting one of the newer billet wheels.
and i guess i did overestimate is hp #'s
i just sold my old wicked wheel to a gentleman the other day who told me he gets 30 mpg in 99 f250 6 speed because of is HHO converter
post #10 of 19 Old 09-25-2013, 11:25 PM
CSIPSD's Avatar
Your going by the overhead?
Forget about the overhead for MPG discussions. Its 100% useless.
Joe
CSIPSD is offline
