Hydra Hex Code EKXO??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-25-2013, 10:03 AM Thread Starter
I cannot find my hex code on the Hex/Box conversion. Any ideas?
Also, is there a way to change the tire size to 35s?
Thanks guys.
mram10 is offline
post #2 of 6 Old 09-25-2013, 07:55 PM
Superstroker127's Avatar
you have to plug the chip into the pcm first then use the data cable to plug into ur laptop(NOTE:keep in mind all this needs to be done with the key off first with the chip plugged into the laptop then turn the key on otherwise it dosent give you the read ECM option also have the pcm plugged back into the truck )Now there is an option on ur computer that says "read ECM" then you save the file and then it tells you what your hex code is i just did mine today also i didnt see anything on there that said changing your tire size i wish it did that..... someone please correct me if im wrong!
2000 F250 SCSB 280k
-Stage 2 160cc injectors from Full Force Diesel
-15 position power hungry performance "Hydra" chip
-Wicked wheel upgrade
-Valair 400hp rated clutch
-Straight pipe
-Wicked Wheel
-HX-35 WG
-leveling kit
-315/70/17 Hankook Dynapro MT's
-05 Harley Davidson edition headlamps
-08+ SD Tow mirrors
Made 336HP-734Ft-lbs on stock injectors with Edge Evolution programmer
haven't had it on the rollers yet
New Engine and Turbo hopefully coming soon
Superstroker127 is offline
post #3 of 6 Old 09-26-2013, 06:57 PM
hansel's Avatar
Quoted: 94 Post(s)
Send Jay (chatham036) a pm, and do not put the key in the ignition you will have a good chance of frying your pcm. I REPEAT LEAVE THE KEYS IN THE HOUSE!!!!!!!!!!
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #4 of 6 Old 09-26-2013, 09:36 PM
Well that was the only way it would ask if you wanted to read the ECM, how else are you suppose to do it ?
2000 F250 SCSB 280k
-Straight pipe
-Wicked Wheel
-HX-35 WG
-leveling kit
-08+ SD Tow mirrors
post #5 of 6 Old 09-27-2013, 06:58 PM
hansel's Avatar
Quoted: 94 Post(s)
The chip is powered by your laptop, but you should talk with Jay if you are having issue's
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #6 of 6 Old 09-30-2013, 12:52 AM
Mearntain's Avatar
What exactly is the "Read ECM" option for? Can I read stored codes with that? I can't seem to find any info on it
2001 F250 7.3 4x4 - Reg Cab, Long Bed
AFE Stage II intake, 4" turbo back exhaust, 4 gauge Isspro pillar, PHP Hydra Chip, 35" BFG All Terrains with Fox 2.0 Shox all around, 4" lift
PSN - Rowe
Mearntain is offline
