Spiral snap ring on the injector? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-18-2013, 06:38 PM Thread Starter
Carpenoctum's Avatar
Cool Spiral snap ring on the injector?
I came across this video of someone working on a 7.3. He recommends the top steal back up needs to be replaced with a spiral snap ring Hercules pt. no. WH-150
I was able to locate the part he used.
Hydraulic cylinder repair seals and kits-Hercules Sealing Products - Hydraulic Seals and replacement cylinders for construction and many other heavy equipment industries.
Any thoughts on this?
Carpenoctum is offline
post #2 of 3 Old 09-18-2013, 06:46 PM
CSIPSD's Avatar
Use Alliant injector O rings. Done.
Some people want to reinvent the wheel.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 3 Old 09-18-2013, 06:57 PM Thread Starter
Good point! I think the OEM are starting to fail at 200,000 miles. I can't hold 2800 ICP past half throttle. Any more and it falls right to 1800...If they go that long again before needing new injectors I'd be happy. Interesting concept though....
