Experience advise needed - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-17-2013, 09:54 PM Thread Starter
Hey guys ,needing some experience advise from those that have BEEN THERE AND DONE THAT. Im considering taking my next step in ref to mods . My truck is a 2003 f250 with 160k miles . Looking to step up my injector size ( truck isn't and want be used for sled pulling or drag racing - just want the power when need be while every day driving ) would love to hear advise on size . Also was looking into a driven diesel regulator return unit ( that's if it's a need be with benifits to my set-up ) . Not looking for an injector that will crush my original tranny . What order would you advise first if both is needed .Below is my current truck mods .
Afe stage 2 intake
Mbrp 4" exhaust turbo back
Driven diesel tank mod kit with hutch mod
DP tuner tunes
38R
SP-1 HPOP
All gauges
6.0L tranny cooler
JW valve body ( not installed yet )
Thanks guys
Boydog is offline
post #2 of 13 Old 09-17-2013, 10:16 PM
the1laf's Avatar
I'll chip in on the fuel system.. (Regulated Returns benefit all setups, modified and stock) Irate Diesel makes an awesome RR kit, I bought the whole competition system and love it. The hard line RR is really clean, the lines look almost factory. I can post pics if you want.
No personal experience with injectors like you want but being you have a PMR motor you'll be limited to Stage 1's - Stage 2's & the 400hp range, that's all the more I'll say on that topic.
Is your HPOP the SRP1.1 or the Billet Stealth? Just curious, I'm looking at a billet..
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #3 of 13 Old 09-17-2013, 10:26 PM Thread Starter
SRP 1-thanks for the response - what exact did you notice different after adding the RR
Boydog is offline
post #4 of 13 Old 09-17-2013, 10:41 PM
JSchuricht's Avatar
The RR is a great idea. I went with the Driven Diesel, was ITP when I bought mine, on my 00. It was one of the first mods I did and made a huge difference in how smooth the engine ran. I used the Irate kit on my 95. Having used both, the Driven kit was much nicer and if you plan on looking at the instructions there is no competition.
For injectors, there are many good builders. I used Rosewood and am quite happy. I would stick with 160/80's for your PMR motor. The trans will still be a weak link even with the valve body.
Driven Diesel kit installed with everything back together.
Irate kit during installation.
JSchuricht is offline
post #5 of 13 Old 09-17-2013, 10:44 PM
the1laf's Avatar
After the install i found what I would describe as a more full power band, smoother running, and noticeably quieter injectors under throttle.
the1laf is offline
post #6 of 13 Old 09-17-2013, 10:49 PM
the1laf's Avatar
JSchuricht: You went to town... I left my turbo in. I'll save that for when my S468 comes in.
the1laf is offline
post #7 of 13 Old 09-18-2013, 04:03 AM
CSIPSD's Avatar
Use the ITP/Driven Diesel kit. MUCH better then the Irate fuel system IMHO.
The Irate one could be good with just a few simple refinements but its not there yet.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #8 of 13 Old 09-18-2013, 05:13 AM
the1laf's Avatar
Take it from the man with experience.. if anyone would know Joe would.
Idk what I'm missing I guess I haven't tore enough of my motor apart yet to know.
the1laf is offline
post #9 of 13 Old 09-18-2013, 05:34 AM
CSIPSD's Avatar
The Irate kit is nice, but all the hard pipes, no flex, and no mount for the regulator... The regulator needs to be mounted somehow, to something. It just floats there with the hard pipes.
Its close, just not as nice, not as well put together as Dennis's kit.
Joe
CSIPSD is offline
post #10 of 13 Old 09-18-2013, 06:22 AM Thread Starter
Advise
Would you recommend this mod before injectors ? If so , what noticeable difference will I observe Joe . Also ,what would you recommend would the most safe injector for my current set up ( referring to first post )
Boydog is offline
