Wix air filter too big? - Ford Powerstroke Diesel Forum
post #1 of 40 Old 09-17-2013, 04:27 PM Thread Starter
usteffenhagen's Avatar
So i got my new filter in the mail today and it is appearing to be too big. The number on the box says 546637 and i know 6637 should be the right size.. any input would be helpful
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 40 Old 09-17-2013, 04:31 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
it does look huge when you first get it. but it fits in their like a glove.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #3 of 40 Old 09-17-2013, 04:31 PM Thread Starter
Here's a pic to show. The new one is sitting on top of the box around the current filter
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #4 of 40 Old 09-17-2013, 04:33 PM
Quoted: 289 Post(s)
it looks like you wont be using the box. just remove the box and hook the new filter upto the intake tube.
k and n kits dont come with a box like that. so im guessing the previous owner just installed a k and n filter in some other type of box.
post #5 of 40 Old 09-17-2013, 04:34 PM Thread Starter
It seems way too long though. And do I gotta take off the guards?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 40 Old 09-17-2013, 04:35 PM Thread Starter
Nevermind I don't know why I asked the last question... But ok ill put her in there ill come back with a follow up
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #7 of 40 Old 09-17-2013, 05:32 PM Thread Starter
So I took out the box. Do i gotta take out the base that goes around the battery also? Because she still doesn't fit
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #8 of 40 Old 09-17-2013, 05:34 PM Thread Starter
It's getting held up on the screw points for the shield around the other filter
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #9 of 40 Old 09-17-2013, 05:57 PM Thread Starter
Calling it quits for tonight. Looks like the only way it'll fit is if i cut off the back side of the battery box at the bottom. Did you have to do that on yours?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #10 of 40 Old 09-17-2013, 06:17 PM
RPM Tim's Avatar
I just did mine yesterday; with just the air box section removed, the bottom mounting "humps" for it held the filter too high. I didn't really want to cut it so I just removed the battery box sections also and used a generic batt tray. Plenty of room then, although I could've gotten away with hacking off those two humps or at least the outer one towards the fenderwell.
Not even sure if any of that is applicable to your setup, but that's what I ran into. Good luck
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
