Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 10-24-2006, 07:17 PM
SULLY1 SULLY1 is offline
Hissing Noise In Exhaust
I Have A 2002 7.3 W/ Western Diesel Ram Air, Superchip Programmer, & Newley Installed S/s 4" Turbo Back Exhaust. Since I Installed The Exhaust When The Engine Is Cold Started There Is A Loud Hissing Noise Coming From The Exhaust. I Beleive It To Be The Waste Gate But Never Noticed It Before. If You Tap The Accelerator It Will Stop But Will Start Again. It Stops After Warmup. Any Ideas?
Old 10-24-2006, 07:30 PM
Jon Jon is offline
The MN Kid!
Mine does that
when it is cold in the mornig. It makes a Sheeooo Sheeooo noise. When you tap the pedal it goes away only to return till the engine is warm. It's the butterfly valve.
Old 10-24-2006, 07:31 PM
Jon Jon is offline
The MN Kid!
Forgot.
But if it didn't do that before you got yourself an exhaust leak.
Old 10-25-2006, 04:16 AM
Not An Exhaust Leak, Whats The Fix For The Butterfly Valve?
Old 10-25-2006, 04:32 AM
00powerstrokin 00powerstrokin is offline
Moderator
Send a message via Yahoo to 00powerstrokin
that is normal. you can't really hear that with the sotck exhaust. it does that when the temperature is below 35 degrees to help warm up the truck. it closes the exhaust backpressure valve which blocks the exhaust creating the hissing noise. as long as it stops when the truck warms up it is normal. mine wnet out and it would hiss all the time if it was below 35 degrees, so i wired mine to a switch and i use it as an exhaust brake now.
Old 10-25-2006, 05:05 AM
Jon Jon is offline
The MN Kid!
I've got stock exhaust!
And mine is loud as %#*& in the morning now. Step on the pedal and bye bye!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
