7.3 temp gauges - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-14-2013, 11:04 AM Thread Starter
7.3 temp gauges
I just bought a set of gauges for my 2000 f250 7.3 and I was wondering where should my temps. Be running at normally I have the exaust temp, trans temp, and fuel pressure gauges.
And I was wondering what degress do I not need to exceed.
honda144 is offline
post #2 of 3 Old 09-14-2013, 12:56 PM
Vannnce's Avatar
Quoted: 13 Post(s)
unloaded with a 4" lift and 35's with baby swamps injectors at ~70 my egts are around 600 and my tranny temp is around 200. It takes my tranny quite a long time it seems to warm up, but ive never had a tranny temp gauge before this one so i guess its normal.
You can let your egts hit 1250 all day long from what ive gathered but much higher than that for any length of time you should drop a gear.
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #3 of 3 Old 09-15-2013, 10:41 AM
Powerstroke Junkie
NCHornet's Avatar
Trans takes 20-30 min to warm up, you are heating up almost 5 gal of ATF, or in my case over 5 gal. Anything over 200 degrees means you need more cooling. I use 215 to 220 as my pull over temp unless I am getting ready to crest the top of a hill. Cure for this is the True Cool Max ( Ford V10 Cooler) or the 6.0 cooler.
EGT's, most use 1250 as redline, but again if you are cresting the top of a grade I would stay in it. It takes over 2 min to heat soak a piston, so brief runs exceeding 1400 degrees is survivable, contrary to internet myth where the engine explodes at 1251 degrees. I have never had mine reach 1250, IIRC 1200 was the highest I hit towing heavy up a very long steep grade. Best cure for high EGT's is more air flow in and out, followed by water meth injection.
Boost should be one of your gauges, I would use boost before FP but if you can have both even better. Stock 15-17 psi is about all you will see. A tuned truck can see triple that, just remember anything over 25psi is shortening the life of the stock turbo.
FP will vary, but 60-70 psi is normal.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
