Brake Flush - Ford Powerstroke Diesel Forum
post #1 of 23 Old 09-09-2013, 10:19 PM Thread Starter
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
Brake Flush
While I'm changing out the front calipers, I figure I'll flush the entire system to get any water out. What are we using this year to flush and replace fluid?
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #2 of 23 Old 09-10-2013, 06:20 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Look on eBay, there are tons of cheap pressure bleeders (I forget the name...). They look like sm "Garden Sprayers" and have Lots of adapters. I bought a complete kit that does most cars (had like 6 different adapters) for under $100. It works GREAT!
NoRalPh is offline
post #3 of 23 Old 09-10-2013, 09:46 AM Thread Starter
Quoted: 19 Post(s)
Great thanks Ive never flushed it before myself (yeah I know, shame on me. It only sees about 5k miles a year) so any recommendations on what goes in?
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #4 of 23 Old 09-10-2013, 01:36 PM
Quoted: 157 Post(s)
I just buy the big bottle at Walmart (Prestone DOT 3 synthetic it's like $10 - buy 2). I think, now that you have the pressure bleeder, just do it more often -vs- buying expensive stuff
Also, don't leave it in the bleeder when you're done, it's still hygroscopic and will pull moisture from the atmosphere...
NoRalPh is offline
post #5 of 23 Old 09-10-2013, 02:57 PM Thread Starter
Quoted: 19 Post(s)
Roger; thanks
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #6 of 23 Old 09-10-2013, 03:03 PM
alaskan155's Avatar
Quoted: 60 Post(s)
dumb question by why not run Dot 4 or DOt 5 fluid?
doesn't dot 4 have better freezing and boiling points vs dot 3?
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #7 of 23 Old 09-10-2013, 03:14 PM Thread Starter
Quoted: 19 Post(s)
I think I heard somewhere that DOT 3 is generic and can be used in DOT 4 rated trucks but that 4 cannot be used in 3 and 5 is in its own category. I did a little Google search but Wiki isnt always factual since anybody can edit the info: http://en.m.wikipedia.org/wiki/Brake_fluid
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #8 of 23 Old 09-11-2013, 02:03 AM
JSchuricht's Avatar
Dot 3 or 4 is fine. Don't use Dot 5 unless your planning on racing the truck and changing the fluid after each race, it's not designed for normal use.
JSchuricht is offline
post #9 of 23 Old 09-11-2013, 09:00 AM Thread Starter
Quoted: 19 Post(s)
Ah okay copy that. Thanks
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #10 of 23 Old 09-11-2013, 09:05 AM
Powerstroke Junkie
NCHornet's Avatar
I have been running the Super Blue Brake Fluid for several years now and I highly recommend it. As for bleeding, I do it the old fashioned way, but I have a son with strong legs, lol!!! The super blue doesn't attract water like the regular brake fluid and it has a much higher boiling point. Because it doesn't attract water it can go longer between changes. I also recommend changing the front brake lines to SS lines, it will really help firm up the pedal.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
