Ways to lower egts - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-08-2013, 06:38 AM Thread Starter
Ways to lower egts
Hello,
The wife and I use our truck to pull our fifth wheel. The last couple times out we experienced turbo surge while pulling on grades. After a bit of research I had a mechanic install a wicked wheel. Since then, I've noticed like many others with a ww that my egts have crept up, 75-100 degress while cruising on the freeway. I don't know if that will stay linear while towing, go up or maybe down due to more boost but we're going on another trip here very soon and I guess I'll find out. I can manage the egts fairly well by adjusting my driving style but was wondering, what sort of mods could be done to help lower those temps back to where they were with the stock compressor wheel? I don't want to do anything exotic and whatever I do has to be CARB compliant or at least look stock enough that the smog police won't fail the truck. Any ideas?
2000 F350 7.3 4X4 SRW, SC, LB, VDO Gauges, JWVB, PHP Hydra, Tru-Cool Max, KYB Monomax, BTM, BD Brakeloc, S&B CAI, zoodad, WW, Firestone Airbags
cpfullback is offline
post #2 of 16 Old 09-08-2013, 06:50 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
aftermarket or free'r flowing exhaust will help. I beleive a aftermarket intake but not for sure. A aftermarket intercool would help out alot and I thing the water methanol would be the most effective.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 16 Old 09-08-2013, 07:14 AM
Quoted: 3 Post(s)
which ww did you install? The new ww2 from dieselsite is supposed to lower egt's.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #4 of 16 Old 09-08-2013, 07:17 AM Thread Starter
Thanks, I have the intake and a free flowing muffler (BTM). Don't want to do water injection. Kind of zeroing in on the intercooler but that seems to get mixed reviews. Hoping to hear from some who have installed a 6.0 intercooler and have actually measured good or not so good results.
post #5 of 16 Old 09-08-2013, 07:18 AM Thread Starter
Just the standard WW. At the time the billet wheels were all backordered.
post #6 of 16 Old 09-08-2013, 07:26 AM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
Is the truck running on stock tuning, or are you running a performance /tow tune?
I know that EGT's are a killer and the quickest way to run EGT's up is adding more fuel. Transmission only tunes give the sensation of more HP (+-25) by maximizing the hp and torque curves of the stock engine.
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #7 of 16 Old 09-08-2013, 08:25 AM
Turbostang500's Avatar
How bout a few numbers.
What rpm are you pulling the grade?
What boost pressure are you seeing?
What exhaust temp are you seeing?
How fast are you trying to pull the grade?
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #8 of 16 Old 09-08-2013, 09:08 AM
Powerstroke Junkie
NCHornet's Avatar
Don't waste your money on the IC the benefits aren't worth the cost. What are your readings? If they aren't near 1200 don't worry about it. Most use 1250 as redline, but the truck will run all day long at 1200. If you are climbing a grade and see temps climbing but you are 1/2 mile from the top stay in it. You can have short bursts above 1400 with no damage, it takes aprox 2 min to heat soak the pistons.
Only thing that will really lower the temps is better airflow and water/meth injection. I would install the Ford AIS, I have run this with the BTM since 2003 and never had a problem with EGT temps. Your plumbing is fine, no need to go to 4 inch unless your 3.5 is totally shot.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #9 of 16 Old 09-08-2013, 09:15 AM
Quoted: 398 Post(s)
Garage
One thing that just occurred to me is the factory downpipe on the 7.3 is rather flat and constrictive. The 3.5" exhaust can be sufficient w/o the stock muffler. Bigger is better though.
post #10 of 16 Old 09-08-2013, 09:19 AM
jesilvas's Avatar
Quoted: 2 Post(s)
The OBS DP is flat, the SD DP is ok.
4R100, 2wd
330,000 + miles
jesilvas is offline
