mounting fuel filters - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-03-2013, 08:27 PM Thread Starter
caged's Avatar
I curtly have water separator and fuel filter mounted on frame rail horizontally at slight down ward angle. Will this cause any issues being like this or should I install vertically and let every one know I have aftermarket fuel system.
2002 extened 7.3L 4" fabtech with procomp steering,37x18, fiber glass fronts,4" straight pipe Edge juice addituide
air aid intake with battery box new interior.
caged is offline
post #2 of 4 Old 09-04-2013, 02:18 AM
CSIPSD's Avatar
They will not filter properly like that, the water filter will not work at all... You cant see my filters unless you crawl under the truck...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 4 Old 09-04-2013, 01:21 PM Thread Starter
caged's Avatar
OK thx I thought so I thank you
caged is offline
post #4 of 4 Old 09-04-2013, 02:28 PM
Justin@DP-Tuner's Avatar
Quoted: 60 Post(s)
Yes, mount them vertical. If it is placed right, you will not be able to see them at all. Here are a couple pictures of my pre-pump filter for example...
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
