Help with pillar gauges!!!!!???? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 21 Old 09-01-2013, 11:04 AM Thread Starter
F250_STROKER_7.3's Avatar
Quoted: 7 Post(s)
Ok so I just installed my pillar gauges
EGT,boost and trans
I wired them into the dime switch but when I turn my dime down they get brighter and the lights stall on and not just come on with the headlights???
Ok and I'd I turn my head lights on then te boost gauge blinks bright and dull constantly
And my boost is only like 5 to 8 psi I did get one time of 15 psi is this right????
And so I need help on the right places to hook my lights up on the gauges..I need all the help I can get???
Thanks
F250_STROKER_7.3 is offline
post #2 of 21 Old 09-01-2013, 05:35 PM
Joel's Avatar
Quoted: 10 Post(s)
http://www.powerstroke.org/forum/7-3...werstroke.html
Hope that helps bud. Good luck
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 21 Old 09-02-2013, 04:53 AM
heisman01's Avatar
Quoted: 49 Post(s)
Is your boost guage mechanical or electronic? They shouldn't be wired into the dimer but the actual light switch as that guide shows. If you don't have a chip those boost numbers are correct. Also did you wire your gauge power in with your lighting wire?
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #4 of 21 Old 09-03-2013, 12:25 AM
CSIPSD's Avatar
EGT,boost and trans
Thanks
What type of gauges?
What brand and model?
You should wire the lighting portion to the dimmer, but the power should be on a KEY on power source.
I'm not sure what your asking...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 21 Old 09-03-2013, 07:30 AM Thread Starter
Quoted: 7 Post(s)
i was wanting to just know if my boost was right because im running like 7 psi at 2200 rpm at 80 mph
and i do have a chip
and i got the glow shift due to low on money but needed something fast cause i now go to school 600+ miles from home
and i was wanting to know if everyone eles hooked theirs up so that the lights on the guages come on as soon as the key is turned and not wired up to headlights..and i dont understand why my boost gauge and only my boost guage which is mechanical but still it is the only gauge that when i turn my headlights on it blinks bright to dime constantly????
i was in a hurry this weekend to get my guages in cause i wasnt home long at all so i figured everything wouldnt be perfect.
post #6 of 21 Old 09-03-2013, 04:04 PM
heisman01's Avatar
Quoted: 49 Post(s)
What type of chip and what setting? If your just cruising at 80 7 psi seems normal. I hooked mine up to the blue wire with a red stripe behind the light switch and try light up when I turn on my head lights. What does your boost gauge peek at and did you do a t fitting into the map sensor or an air heater plug delete? Do the other gauges function properly?
post #7 of 21 Old 09-04-2013, 03:36 AM
CSIPSD's Avatar
I'd love to help you... But I have no idea what your trying to say...
Joe
CSIPSD is offline
post #8 of 21 Old 09-04-2013, 05:30 AM Thread Starter
Quoted: 7 Post(s)
im saying that my boost gauge flashes bright to dime non stop..but only if my head lights are on.
if i try to dime my dash lights it makes my guage lights twice as bright.
post #9 of 21 Old 09-04-2013, 05:38 AM
Jerrybizzle's Avatar
Quoted: 21 Post(s)
If you have a multimeter or other way of checking to see which fuses have constant power, key on power and power when started it will help wiring them in. Constant vs switched power then the dimmer goes where the instructions above state. Pop the headlight switch panel off and use the recommended spot in the above instructions.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #10 of 21 Old 09-04-2013, 08:15 AM
CSIPSD's Avatar
Dim as in Dimmer...
Not Dime.
That helps.
You cant hook the Glow crap gauges up to a dimmer, they have to be on a constant hot lighting (marker lights). They can not be dimmed other then a two setting thing in the gauge...
Other then that, there glow crap, you get what you pay for.
Joe
CSIPSD is offline
