What other info does block s/n help decode? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-01-2013, 06:56 AM Thread Starter
So, I found my block serial number and verified it to be well before forged rods were in the picture. What other info would the production serial number on the block help you decode for engine internals? better vs weaker injectors , bad engineering design on sealing surface etc? I know manufacturers are always changing little things along the way, I just didn't know what else the number could decode. Thanks for any insight.
2000 F350 Crew Cab 7.3 liter 4x4 short bed, 6 pos w/PHP, 6637 filter, hutch, harpoon, 4" downpipe, 5" exhaust, ISSPRO gages, 305 series tires, stock suspension with level kit up front, '05 headlight mod.
2001 F250 ECSB 4x4 - sold
2001 F250 CCSB 2WD -sold
2002 F250 ECSB 4x4 lifted -sold
Mama's 2009 Expedition EL 4x4
biscayne is offline
post #2 of 2 Old 09-02-2013, 10:40 PM
CSIPSD's Avatar
Nothing...
The block gets pulled from a big pile to be built...
Your 2000 should have Forged Rods and will have AD injectors...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
