HPOP Options - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-27-2013, 03:45 PM Thread Starter
Dr.Evil's Avatar
HPOP Options
Pretty sure my HPOP took a crap last night (oil all over the engine, coming from that area) so figured it was a good time to upgrade.
Looking for thoughts on the best pump for my build:
01 PMR engine - Stage 1 SS injectors, GT38R, Napa intake, 4" straight out exhaust, DP Tuned. I realize I can't do much more with the PMR engine, so don't need anything crazy. Just something that will work well with my set-up. Probably will throw a regulated return in as well.
Thanks!
2011 F-250 Lariat Ex LB 6.7
2001 F-250 R.C. LB 7.3
Dr.Evil is offline
post #2 of 4 Old 08-27-2013, 04:08 PM
layson's Avatar
Quoted: 82 Post(s)
You sure you didn't just blow an oring? Might be a very simple fix....
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 4 Old 08-27-2013, 08:12 PM Thread Starter
Dr.Evil's Avatar
It could be, but I've been wanting to upgrade for a while now so seems like a good time to do that. Just need to figure out what my best option is that won't break the bank. Thanks.
Dr.Evil is offline
post #4 of 4 Old 08-27-2013, 09:01 PM
CSIPSD's Avatar
AD from Dieselsite or the SRP 1.1...
However I doubt there is a single issue with your HPOP...
You blew a HPO line or o-ring.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
