To wastegate or not? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-27-2013, 01:56 PM Thread Starter
03ranger30's Avatar
I am looking at doing a little uprgrading to the stock turbo and had a couple questions. I am buying a used turbo so I can work on it and still be able to drive my truck.
I plan on doing a rebuild and adding a wicked wheel and deleting the EBPV. I was thinking about getting the non-waste gated 1.00 A/R housing, but figured I should ask on here as to whether or not having a wastegate is a good idea.
Thanks
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #2 of 6 Old 08-27-2013, 02:31 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Well if you plan on making big boost numbers you would just have to watch your gauges so you dont over boost and blow something up. Otherwise if your at stock levels id say no wastegate on a 7.3 isnt a terrible idea but thats my opinion
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 6 Old 08-27-2013, 02:54 PM Thread Starter
03ranger30's Avatar
Well it would probably just with a tune, exhaust and intake on that turbo....anything else and I would get a 38r, which I plan on doing anyways.
Charlie
post #4 of 6 Old 08-27-2013, 03:12 PM
Thuglike's Avatar
You do not need a wastegate.
Thuglike is offline
post #5 of 6 Old 08-27-2013, 03:19 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
if your staying stock just ditch the wastegate.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #6 of 6 Old 08-27-2013, 03:25 PM Thread Starter
03ranger30's Avatar
Well like I said, the most I will have on this setup is a tune, exhaust and intake. Anything more than that will more than likely be a 38r and probably stage 1s.
Charlie
