Fire Ring Hot Re-torque Questions? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-25-2013, 10:52 PM Thread Starter
Pwnm30rdi3's Avatar
Hey Guys!
I just got around to finally dropping in my freshly rebuilt 7.3.
I currently do not have the radiator support and fenders on my truck, I figured leaving them off would give me more room to do the hot re-torque.
I have a few questions before tackling this job!
1.) Is it safe to run the motor to operating temp without water/ radiator hooked up? I have an IR Temp Gun.
2.) When performing the hot re-torque, I start in the center of the head and work my way out, correct?
I've also heard of some people filling the block with water and then leaving the block heater on throughout the night in order to heat up the engine for a fire ring hot re-torque. What are your thoughts on this?
Thanks guys,
Andrew
1997 F350
Mahle Ceramic Coated Pistons (De-lipped), Billet Crower Connecting Rods, DI Chromoly Push Rods, Beehive Valve Springs, Fire Ring Headgaskets, ARP Head Studs, Mike's Main Girdle, Melling LPOP, Terminator Dual HPOP, 300/200 Injectors, Dual SD Fuel Pumps, Billet Aluminum Intake Plenums, 6.0 Mishimoto Intercooler, Compound Turbos (Primary = 62/68 & Atmospheric 82/88), John Wood Tranny, 4921 Transmission Cooler, Batteries Relocated to Bed
Pwnm30rdi3 is offline
post #2 of 14 Old 08-25-2013, 10:54 PM
CSIPSD's Avatar
Dog house?
Is this a van or?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 14 Old 08-25-2013, 10:59 PM Thread Starter
Pwnm30rdi3's Avatar
Originally Posted by CSIPSD View Post
Dog house?
Is this a van or?
My bad, its an f350 dually. I'm used to calling it a dog house.
I have left the rad support, fenders, hood, and wheel wells off.
Edited the OP to prevent confusion.
1997 F350
post #4 of 14 Old 08-25-2013, 11:24 PM
CSIPSD's Avatar
You need to get it up to operating temp, which will require more then just a block heater.
Joe
CSIPSD is offline
post #5 of 14 Old 08-26-2013, 06:27 AM Thread Starter
Pwnm30rdi3's Avatar
So is it safe to start the engine and let it idle ~10 min without water in the block? I was always under the assumption that running an engine without water for a short period of time was okay.
Thanks Joe!
~ Andrew
1997 F350
post #6 of 14 Old 08-26-2013, 07:52 AM
CSIPSD's Avatar
Watch the oil temp... Dont hook up the water pump...
Your fine.
People drive around all the time with completly filled blocks, granted there is water in the heads.
Joe
CSIPSD is offline
post #7 of 14 Old 08-26-2013, 08:23 AM Thread Starter
Pwnm30rdi3's Avatar
Your fine.
I already have the water pump and fan on the front of the motor, whoops. I almost feel as it wouldn't be hard to rig up a bucket of water and 2 cheap autozone hoses or something for this first start..
1997 F350
post #8 of 14 Old 08-26-2013, 08:50 AM
layson's Avatar
Quoted: 83 Post(s)
When we did Tylers we put on the radiator and everything. Let it run and get up to temp and then we did the hot torque with most of it all still on the truck. You don't need to pull that all off to do the hot torque. I think we could get to all the studs and if we couldn't get to the back ones, we just unbolted the motor mounts, stuck a 2x4 under the manifold and rocked the motor to get to them. Sucks having to pull the injectors and re-oring them all.
I don't trust those infrared guns. I was having oil temp issues running 260 degrees and that gun read like 220. I think there are a lot of losses on the exterior face of the block.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #9 of 14 Old 08-26-2013, 06:23 PM
CSIPSD's Avatar
You dont have to replace the o-rings, just the coppers... Just FYI.
Joe
CSIPSD is offline
post #10 of 14 Old 08-26-2013, 08:34 PM Thread Starter
Pwnm30rdi3's Avatar
Is it mandatory to replace the copper bushings?
On my old SD I pulled the injectors to have them tested and didn't replace them.
Thanks for all your input and help(:
You guys are great!
1997 F350
