Which injectors? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-24-2013, 02:15 PM Thread Starter
Which injectors?
I'm going to be replacing my hpop here soon most likely with the t500 and was wondering which Injectors does that work with. Or which hp would be the best to get. Are they hard to replace with the hpop out?
DoubleARanch is offline
post #2 of 12 Old 08-24-2013, 07:07 PM
Quoted: 725 Post(s)
You've never worked on a 7.3 before have you?
It will work with just about any injector.
Corey@CNCFAB is offline
post #3 of 12 Old 08-24-2013, 11:36 PM
JSchuricht's Avatar
The HPOP isn't in the way for installing injectors. IIRC Joey said it's good for around 200 or 238cc before you start running out of oil. The big question is what are your goals for the truck.
JSchuricht is offline
post #4 of 12 Old 08-25-2013, 02:10 PM Thread Starter
No actually I haven't. I just got this truck earlier this year and the hpop is leaking now and I was looking at replacing it with a better one but didnt know if the t500 would work with stock injectors or not or would it be better to change them to something different.
post #5 of 12 Old 08-25-2013, 02:25 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
it will work great with stock injectors.
if you plan upgrading injectors then the t-500 will run them as well.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
post #6 of 12 Old 08-25-2013, 04:25 PM
bigpanther2004's Avatar
Id look at going with a adrenaline or a stealth 1.1 over the t500. If ur not looking for big HP then just go with a stock one, but going bigger wont hurt. Where is ur hpop leaking? could just get a repair kit and fix the one you have.
bigpanther2004 is offline
post #7 of 12 Old 08-25-2013, 05:19 PM Thread Starter
Well that's what I was going to do. But the o rings arnt leaking. The only thing I can think is the non replaceable plug thing but I'm not sure so I was just going to replace the whole thing. Do you know if a dealership will do the plug. I would do it but I just have any time. Is the stealth one better for stock Injectors your saying?
post #8 of 12 Old 08-25-2013, 07:03 PM
Quoted: 725 Post(s)
I guess it all depends on what injectors and HP goal you think you may want. You'll be just fine with something like a set of 238/100 hybrids (which can easily put you in the 500hp range with supporting mods) as they use much less oil and the stealth and adrenaline aren't necessary. Any single shot smaller injector will work great as well as stock injectors.
Personally, I got a good deal on my Stealth and eventually I plan on running 250/100's or 200's. Not sure which set I'm gonna go with though. But that's the only reason I got it. If I knew I was going to stay with my 160/100's, I definitely would have a T500.
Take a while a think about what your goals are as per tow rig, DD, weekend warrior at the track??? There are loads of proven options out there.
post #9 of 12 Old 08-26-2013, 08:45 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
What year?
If a 99.5 up and your going to a single shot stage 1 then just keep your 17*
If going to stage 2's get a HPOP with more Volume as that's what's needed.
If keeping your splits """""""""""""""""""""""""""""""""""""""""""""""""" """"
If going large Hybrids """""""""""""""""""""""""""""""""""""""""""""""""" """""""
If small Hybrids keep your 17*
CT Performance, Inc. is offline
post #10 of 12 Old 08-26-2013, 08:50 AM
CSIPSD's Avatar
Strange...
Stock 17* HPOP... 250/200's... 520hp...
Same stock 17* HPOP... 230/100... Still no HPO issue...
HPOP's are a hot seller, easy money...
If I were to get one at this point I would get the SRP1.1, however there are other options out there that are up and coming.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
