Bigg Boost - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-23-2013, 05:45 PM Thread Starter
Quoted: 21 Post(s)
Bigg Boost
Anybody ever check out powerstroke help. He mentions Bigg Boost... Any insight?
The Next Level is offline
post #2 of 6 Old 08-23-2013, 05:52 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 53 Post(s)
Feedback Score: 7 reviews
What are you trying to ask?
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #3 of 6 Old 08-23-2013, 05:55 PM Thread Starter
Quoted: 21 Post(s)
Any insight on Bigg boost, I am new to the diesel area, checked it out on ebay and cant find anything.
post #4 of 6 Old 08-23-2013, 07:08 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
hes either referring to an afe filter called big boost, instead of the 6637 filter.
or its an electronic boost fooler thats pointless.
or it could be a 10k mod.
all of these things arent worth getting/doing.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #5 of 6 Old 08-25-2013, 09:10 PM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 31 Post(s)
No - the Biggboost he's referring to is the map pressure sensor fooler for people generating more than 20+ lbs of boost from the turbo, so that it doesn't cause the map to defuel the engine.
It's a part that's extremely overpriced on ebay.
If anything - go to DieselSite.com and get a better alternative from Bob!
http://www.dieselsite.com/boostreliefvalve.aspx
Unless you have the tunes and the turbo that are actually putting out over 25+lbs of boost - this is not needed.
and if you are! i'd invest in ARP or h11 studs first - otherwise you'll loose a head gasket pretty quick.
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
post #6 of 6 Old 08-26-2013, 12:44 AM
CSIPSD's Avatar
The old big boost was just a small copper tube with a very small hole drilled in it to allow any pressure vented to the wastegate to not allow it to open...
Unplug it if thats what your going for.
As to being worried about studs at 25 psi...
There is no reason to worry about studs at 25, 30, 35 or even 40psi as long as you are using good tuning.
I could write a tune that would blow the heads right thru the hood at about 7psi... Its not about boost pressure (0-50 or more) but about cylinder pressures (which can exceed 2600psi...)...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
