1.0 or 1.15 housing with ww2? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-17-2013, 03:29 PM Thread Starter
Feedback Score: -1 reviews
Ive been reading and searching but still not 100% sure. Given that the 1.15 is known to spool a little slower but offer better egt's I was wondering which would make a hood DD and tow setup.
2000 7.3 ccsb BTS 4r100,frx,coolant filter,custom intake,mbrp turbo back,Php FU,walbro 392,hi flow outlet,turbo master
Pro comp 6.5,bilstein 5160 front/rear,pro comp ladder bars,moto metals/37" hankooks.
n54power is offline
post #2 of 9 Old 08-17-2013, 04:09 PM
CSIPSD's Avatar
On what turbo? Stock or 38R?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 9 Old 08-17-2013, 04:09 PM Thread Starter
Stock turbo
n54power is offline
post #4 of 9 Old 08-17-2013, 04:12 PM
CSIPSD's Avatar
Leave the stock housing alone... You have already spent money on a outlet, on a wastegate controler and now an added compressor wheel...
By the time your done, you will have spent more money then you would have picking up a 38R.
Joe
CSIPSD is offline
post #5 of 9 Old 08-17-2013, 04:22 PM Thread Starter
$50 on the outlet and $50 for the TM. Add in the wheel and I'm into it for $300.
Another $200 and I'm still alot less than a used 38r.
n54power is offline
post #6 of 9 Old 08-19-2013, 04:13 AM
ThomasvillePavers's Avatar
Where are you getting your parts for that cost? the outlets I find are $200...
*Edit: I think modding your stock turbo isn't a bad idea for the money depending on your final goals for the truck, $500 +/- for a good rebuilt turbo that serves its purpose makes more sense than $1400 for a 38R if you don't need it.
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #7 of 9 Old 08-20-2013, 10:16 AM Thread Starter
I watch craigslist and I barter parts off my parts motors.
I was thinking a 1.0ar would give me a little more top end and better egts
n54power is offline
post #8 of 9 Old 08-25-2013, 10:05 AM
Joel's Avatar
Quoted: 10 Post(s)
I have a van turbo with the 1.15 housing an BD's billet wheel.
I really like the way it drives and I can't get the EGT's too high even if I try.
I can't comment on the 1.0 housing because I never had one
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #9 of 9 Old 08-25-2013, 07:55 PM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 35 Post(s)
I can understand CSIPSD's position.
The 38r's are a direct bolt-in upgrade - pure and simple.
But the prices on those start from $1300 up to $2000 depending on who you go with.
Now from all the threads I've come across - the 1.00 to 1.15 A/R debate has been pretty extensive.
Now unless you're doing something really high flow and horsepower - the 1.00 will be fine. But there's nothing wrong with using the 1.15 either.
I just finished building my "hodge podge parts" budget turbo.
Core - 100 Banks 1.00 A/R turbine housing - 300, ATS 4" Ported Compressor housing- 250
Garrett Rebuild kit - 75, BD wastegate - 100 BD 9 blade billet Wheel - 200
Now at just over $1000, I consider myself ahead of the game price wise compared to the 38r's out there.
I may not have the fastest spool up compared the 38r's, but it will certainly be better than stock, and if not darn close to the performance of a 38r.
But with the WW2 and a 1.00 housing - I'd just get an upgraded wastegate and call it done for a good tow/DD turbo!
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
