Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 05-13-2008, 10:36 AM
99 Stroker 99 Stroker is offline
Wastegate
ok so dont make fun of me here, but i have an early 99 PSD with stock turbo, and i was just wondering if i should unplug the wastegate, and if so what to do with the line and the nipple coming off the gate. Other mods are in my sig. any help is appreciated, thanks.
Old 05-13-2008, 10:53 AM
farm stroker farm stroker is offline
if you pull the line off just plug it with a screw or something otherwise you can tighten up the actuator rod going to the turbo
Old 05-13-2008, 10:57 AM
scheidt27 scheidt27 is offline
put it over one of your intercooler tube clamps
Old 05-13-2008, 11:08 AM
makaveli200369 makaveli200369 is offline
I have a late 99. If you unplug the wastegate will the turbos life be shortened greatly? Also with stock injectors will it handle the increased boost?
Old 05-13-2008, 11:11 AM
^^ yes what he said i would also like to know!!
Old 05-13-2008, 01:47 PM
ive been told not to get over 25-30psi on a stock turbo ir it'll go eventually, and stock injectors wont matter
Old 05-13-2008, 02:00 PM
Anyone know what boost it will hit with the wastegate unplugged? I'm guessing like 35lbs
Old 05-13-2008, 03:06 PM
so all in all the stock turbo is it a good idea to unplug the gate? i think im gonna do it
Old 05-14-2008, 05:46 AM
Southpaw Southpaw is offline
Faith, Family, Country
First of all...Noone here is going to make fun of you. Noone is born with this knowledge in our heads..
Mine makes about 31-32 psimax with the red line disconnected and my other mods.
Heck, try it out! Just remember, the wastegate opens at 22-24psi for a reason. If you force your stock turbo to see 30+ psi all the time, it will damage it eventually. I have had mine unplugged for sometime now 1+yr. It does get out of it's 'safe' range now and then, but I try not to hammer on it too bad all the time...
:teocents:
later
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
