7.3 Exhaust Help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-15-2013, 10:13 AM Thread Starter
7.3 Exhaust Help
I am planning on making my own exhaust.
I will be buying a 4" downpipe. From there I want to do 4" straight pipe back to a 4" y-pipe I just bought.
Now my question, from the Y-pipe should I do 90* and straight out to the sides, or 45* and go out at an angle to the sides.
I plan on dumping the exhaust in front of the wheels. Also don't plan on running it all the way to the edge, stop like 6" under the body.
I know the 90* will cause more backpressure, but I doubt it will make any huge difference. At this point, I would like it to sound good.
Really I am not sure if either way will net any difference in power or sound.
zillafreak is offline
post #2 of 5 Old 08-15-2013, 11:41 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
Sounds like your aiming for what I've done. I need to bump my entire system to 4" but I have a 90 that turns into a 4" Y pipe that comes out in front of the rear wheel with 2 4" tips. I figure I'll revamp the whole thing and go 4" turbo-back to 6" tips someday.
I love the look. Nobody has dual pipes dumped in front of the rear tire.
Here's a photo that was readily available: http://i1296.photobucket.com/albums/...psc67a601b.jpg
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 5 Old 08-15-2013, 12:06 PM Thread Starter
you are doing the same side, I was thinking about doing both sides, one out each.
I like the way yours look. I don't have a lift or anything on my little red truck.
post #4 of 5 Old 08-15-2013, 12:19 PM
Quoted: 19 Post(s)
That might be difficult crossing the driveline and dumping under the fuel tank.
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #5 of 5 Old 08-15-2013, 12:42 PM Thread Starter
Ya, kind of what I was wondered about. Guess I will check it out and see what I can find.
