4 inch or 5 inch straight pipe - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-12-2013, 06:15 PM Thread Starter
Cummins_Killer's Avatar
I have a 99 7.3 and am looking to straight pipe it, im wondering the diffrence between a 4 inch and 5 inch straight pipe, i want it to be loud but still sound good. Also can anyone recommend me a kit for it? Thanks
Cummins_Killer is offline
post #2 of 10 Old 08-12-2013, 06:47 PM
usteffenhagen's Avatar
4" is all you need
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #3 of 10 Old 08-12-2013, 09:01 PM
Quoted: 725 Post(s)
^^^^what he said. Put a 5" tip on it
Corey@CNCFAB is offline
post #4 of 10 Old 08-12-2013, 09:07 PM
^^^^ what he said lol. I got one on mine and it'll sound really good
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #5 of 10 Old 08-12-2013, 09:08 PM
Plus MBRP is quite reliable. Make sure you get a 4" downpipe too
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 10 Old 08-13-2013, 04:36 PM
heisman01's Avatar
Quoted: 49 Post(s)
http://www.xtremediesel.com/MBRP4PLM...mS6200PLM.aspx
Use diesel10 as the coupon code at check out and get 10% off
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #7 of 10 Old 08-13-2013, 07:00 PM
03ranger30's Avatar
5" sounds better in my opinion though, and looks cooler
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #8 of 10 Old 09-01-2013, 09:05 PM
GodMike's Avatar
I have 5" straight... the choppy reverb is awesome! Turns a lot of heads... lose a tad bit on the bottom end but makes up for on the top.
2000 CC SWB 4x4
CCV Delete Mod, Zener Diode, Boost Tube, Hot Side MAP, DIY Intake, 120HP Programer, Modded 09' Tail Lights, DieselSite 203* Thermostat and Aluminum Housing, 5" Diamond Eye turbo back straight pipe, 50 Cent Mod
GodMike is offline
post #9 of 10 Old 09-03-2013, 06:54 PM
PSDx's Avatar
I've got the 5", my buddy has the 4". I prefer the 5" as I like being the loudest diesel on the block, but only for that reason.
2001 F-350 CC Lariat 7.3
-Superchips Flashpaq
-5" MBRP Turbo Back
- Pro Comp 4" lifts
- Method Standard wheels 16"
- Toyo mud terrains 35"
-Work in progress
PSDx is offline
post #10 of 10 Old 09-03-2013, 08:02 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
5in is just a deeper louder sound then the 4in. Personaly you better off buing the pipe and making it your self and have a side dump infront of the wheel cuz its way cheaper and only kills a few hours
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
