Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 05-06-2008, 08:20 PM
black99stroker black99stroker is offline
question about ts chip
I installed a ts performance chip on my truck today and im having problems when running it on the 140 hp setting. All other settings work great, but on 140 it wont hardly run. It lopes so bad it will stall and even trying to ease into the throttle it will fall flat on its face and then gradually recover. Any ideas?
Old 05-06-2008, 08:24 PM
nic0084 nic0084 is offline
TEXAS STROKER
weak HPOP, low oil level, bad connection...???
Old 05-06-2008, 08:25 PM
Patrick Patrick is offline
Send a message via MSN to Patrick
ya...check your oil level. Plus your stock truck really doesnt have the Hardware to support that file.
Old 05-06-2008, 08:34 PM
i checked the oil and it was fine. My first thought was that i had a bad connection so i took it apart and cleaned it again but had the same results.
Old 05-07-2008, 07:58 AM
Could a bad injector o ring cause this?
Old 05-07-2008, 08:33 AM
hondo997.3 hondo997.3 is offline
i have the same problem and still have not found a solution
ill probably end up having TW reburn it
Old 05-07-2008, 08:56 AM
toddy toddy is offline
Sounds like a bad program to me. I have heard of Ts chips doing that in the past
Old 05-07-2008, 09:00 AM
GoldieStroker944 GoldieStroker944 is offline
well i have almost all the same mods as him and i run the exact same file 140 all the time cause i get better mileage my truck runs fine on it but i am going to have tony reburn it for me but
as to the problem with the chip i would say it is a connection problem take it out again and clean it good i mean real good i had a huge problem with this after i cleaned it it worked fine
good luck
Old 05-07-2008, 09:04 AM
redstroker_2002 redstroker_2002 is offline
KVFD
good luck
what do your egt's run? that doesnt sound good running on a high hp file all the time....
Old 05-07-2008, 09:10 AM
i dont have your guages yet so i dont know lol prolly not a good idea i know but i only drive on the interstate i dont hot rod around and stuff but hopefully i have some form of monitering system soon fpr my trucks sake
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
