Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 05-03-2008, 10:01 AM
ONE BAD EXCURSION ONE BAD EXCURSION is offline
Swamps Injectors
Is any one running swamp injectors. I have their split shot stage 1's and my excursion makes more noise and my milage around town sucks. On the highway it gets around 17 but in town it only gets 11.5. Is this normal. When taking off at stop lights it sounds like it is skipping or missing. Is there some why I can check to make sure that the injectors are preforming correctly.
Old 05-03-2008, 10:05 AM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
How long have you been running them? Has it done this from day one?
That mileage sucks. I have the equivalent of stage 4 injectors and I get 14.5-15.5 around town and 17.9-18.1mph on the highway. On 35's mind you.
Old 05-03-2008, 10:11 AM
The injectors where installed in February. They have been like this from day one.
Old 05-03-2008, 10:14 AM
First off, I would call and talked to Jonathan or Dave about it.
You could run a cylinder contribution test and a buzz test to see if everything tests out good. You need either Auto Enginuity or another type of scan/test tool for this.
Old 05-03-2008, 10:24 AM
I will call them monday. Can a local ford dealer run those test.
Old 05-03-2008, 10:29 AM
Yes they can. Is there a local diesel shop in town? They will probably be cheaper and maybe know more about injectors.
Old 05-03-2008, 12:14 PM
Not near me. All we have is a local ford dealer.
Old 05-04-2008, 08:51 PM
White Buffalo White Buffalo is offline
Have you talked with T Wildman about this and get his thoughts?
Old 05-04-2008, 11:02 PM
Southpaw Southpaw is offline
Faith, Family, Country
I know Alabamafrog used to/still is running swamps injectors...
later
Old 05-05-2008, 07:43 AM
Hey, White Buffalo I saw on another post you say Royal Purple is a waste of money. That is what I am using. Do you think if I change back to rotella-t it will get better.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
