coolant filter? - Ford Powerstroke Diesel Forum
post #1 of 34 Old 08-04-2013, 06:42 PM Thread Starter
PowerSTOKED_Bryan's Avatar
coolant filter?
hey guys, the water pump blew out on my truck this past weekend and I had a couple questions about the coolant filtration kit....just curious if people noticed a difference who ran them. I bought the truck about three years ago and the previous owner had just replaced the pump then....I would think it should last longer than three years....ive been skeptical on the filter kit, but after this, maybe it is worth it? also, ive seen some talk about switching coolant to ELC? what are the benefits of that? thanks!
2000 Ext. Cab F-250 Lariat(TOTALED)
2001 Reg Cab F-350 (mine)
AFE Intake
No Limit Tuning
4" straight pipe
2005 Harley Davidson Headlights
Early 99 Reg Cab (hers)
Tymar
Edge Evolution (temporary)
5" straight pipe
PowerSTOKED_Bryan is offline
post #2 of 34 Old 08-04-2013, 06:46 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Filter - yes. My pump lasted 11yrs till I snapped off a bolt in it
Then a reman didn't last long, so I bought new.
Cat EC-1 rated coolant requires no maintenance (basically) where as your regular green requires a lot, whether you know it or not.
Also, green is not diesel rated, Cat EC-1 specifically is diesel rated.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 34 Old 08-04-2013, 06:51 PM Thread Starter
ok, looks like I will be making the coolant switch...what about the 203* thermostat?
AFE Intake
No Limit Tuning
4" straight pipe
Tymar
5" straight pipe
post #4 of 34 Old 08-04-2013, 06:55 PM
ngaraiderman's Avatar
Here is the ELC I got at O'Riley's. And I used a sinister coolant filter on my 6.0. Peace of mind knowing it is there
ngaraiderman is offline
post #5 of 34 Old 08-04-2013, 07:08 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Just be sure to get the concentrated coolant.
I use the 203*F thermostat. I had puking issues from the degass bottle, but just from the additional heat in Texas summer. Finally found a good coolant level. Needed? No. Do I like it? Yea.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 34 Old 08-04-2013, 08:31 PM
Eco Taxi's Avatar
Yes for coolant filter
Def ELC - I got zerex from NAPA
Same as jesilvas for 203 - didn't need it but glad I got it
Look at this for routing your coolant filter
Best hose routing for coolant filter
I bought my coolant filter kit and since it is T'ed into my degas I've noticed the warm up has been out of whack - as the link above states it bypasses the t-stat - so I'm re-routing my line out of the coolant filter
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #7 of 34 Old 08-05-2013, 03:41 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Yay, glad to see my threads linked
Also, get the upper radiator hose for DUAL alternators.
And get the dieselsite billet thermostat housing no matter what t-stat you get
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 34 Old 08-05-2013, 03:54 AM
CSIPSD's Avatar
DO NOT waste your money on a 203* stat... If your stock, leave the stock stat in there. If your modded go with the 180* stat...
As to coolant...
I run the green stuff with precharged coolant filters. In 1.5 million miles I have never had a coolant related failure.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #9 of 34 Old 08-05-2013, 05:18 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
As to coolant...
^^ agreed. 203* T-stat did nothing for my truck except make the AC awful in the summer.
As far ELC's, Cat EC-1, Navistar B-1, and Cummins 14603 are the dominant specs and odds are most coolants that meet one (ie. Delo ELC) meets all of them. As mentioned above they require less maintenance than green or gold. Currently I am running Zerex G-05 (same thing as MC gold) but I will be swapping to ELC cause I am selling the truck to my father and the test strips will be one less thing for him to deal with.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #10 of 34 Old 08-05-2013, 06:26 AM
jesilvas's Avatar
Quoted: 2 Post(s)
My AC is still great in the Texas summer.
4R100, 2wd
330,000 + miles
jesilvas is offline
