Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 10-12-2006, 05:43 PM
PSDfan99 PSDfan99 is offline
blub blub blub
1999 Turbo Swap?
I have an early 99 PSD with the factory turob setup.
Is there a way to convert my motor to a late 99-03 7.3L turbo setup?
What will I have to do to make it work? Is it worth the conversion?
Thanks, Jake.
Old 10-13-2006, 03:46 PM
shoit2ya shoit2ya is offline
Send a message via AIM to shoit2ya Send a message via Yahoo to shoit2ya
Thanks, Jake.
I was wondering the same thing. My turbo shaft has a slight wobble in it and I would rather replace it with a better turbo then the old one. Please help us!!!!!!!
Old 10-13-2006, 03:50 PM
I have also been told that I would need the pedistal and a blank flange? does this sound right?
Old 10-13-2006, 05:43 PM
Logan Logan is online now
The Fat Mod
If you just do a rebuild kit, if you have the bigger tubo, why would you want a newer style one?
Old 10-13-2006, 06:23 PM
I thought the older turbo was smaller than the 99.5?
Old 10-13-2006, 06:40 PM
Stroked95 Stroked95 is offline
I know there are some differences between the two, just not sure what all of them are I know the intakes are smaller than the 99.5 and the pedistals are different also. Check this out it might help some
http://www.dieselsite.com/index.asp?...ROD&ProdID=276
Hope it works
Old 10-13-2006, 06:51 PM
thanks for the info!!!
Old 10-14-2006, 08:38 AM
mech2161 mech2161 is offline
There is not enough to gain unless you go to the aftermarket BB turbo or a Turbonetics. To use either of these you need the 99.5 and up kit to do this.
Old 10-14-2006, 08:45 AM
Maintain Maintain is offline
sexy
Send a message via AIM to Maintain
The early 99 is smaller, but it's not worth the headache of changing stuff over to the late 99 setup. I'd go with an aftermarket turbo like Mech said that way you have a considerable gain for the mone/work put into it.
Old 10-14-2006, 11:17 AM
Does anybody make aftermarket turbo for the smaller 99?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
