Need Some Help! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-28-2013, 06:48 PM Thread Starter
Need Some Help!
New to the forum.
I have been reading alot on here and learning, But I could really use the input from you more experianced guys on mods.
I gust Picked up 1999 F350 superduty crew cab LB 4x4 with the 7.3 powerstroke Dually. I have had 2 F250 powerstrokes before but never did any mods to them.
After reading on here about power chips, Im going to go with the wild mans 6 pos chip from TDP. 4" exhaust is on order already will be here tuesday. I have added the Edge insight for my gauges, works great. I have the exhaust temp thing coming also for the edge.
What i need from you guys is what other mods should I do before i order the chip. I was thinking of a cold air intake? what one? and what else is really needed for better fule millage.
I will use the truck as a daily driver and towing boats and trailers.
BigWhiteRack is offline
post #2 of 12 Old 07-28-2013, 06:53 PM
jesilvas's Avatar
Quoted: 3 Post(s)
A DIY Tymar style intake is the most popular.
Really the only other thing for mileage is to make sure that all your sensors are feeding correct info to the PCM and you aren't leaking fluids and brakes aren't stuck.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 12 Old 07-28-2013, 08:13 PM
the1laf's Avatar
With a 4" exhaust, intake and tunes you've covered the major inefficiencies of the stock 7.3L.
Like jesilavs said, regular maintenance is your biggest factor. Keep everything in correct working order and you should be good.
Popular intake is the DIY Tymar: Napa #6637 filter and a chunk of 4" exhaust pipe(you'll need all of what's in your kit but it's easy to find)
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #4 of 12 Old 07-28-2013, 08:19 PM
timmyboy76's Avatar
Welcome to guzzle's Ford PSD Web Pages
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 12 Old 07-28-2013, 08:36 PM
usteffenhagen's Avatar
I don't know if it will come in your exhaust kit, but a 4in. down pipe should also be added
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #6 of 12 Old 07-28-2013, 08:40 PM
Raul@Stealth Automotive's Avatar
if you want a full intake kit you cant beat the price of the S&B unit... we run it on our work truck.... if your interested in a package deal i can set you up with the intake and the TW chip to save you some money
-Raul
Raul@Stealth Automotive is offline
post #7 of 12 Old 08-01-2013, 11:21 AM Thread Starter
Thanks everyone for the input. Ok next question, putting exhaust on after work. Is it possible to put the temp sensor in the down tube? Or does it have to be in specidic spot in manifold? And were is the best spot. Drilling and taping the manifold is gona suck.
post #8 of 12 Old 08-01-2013, 01:03 PM
timmyboy76's Avatar
if your referring to the EGT/PYRO probe, you can install it in the downpipe, close to the exhaust oulet. Most though, install in the d/s manifold, before the uppipe.
post #9 of 12 Old 08-01-2013, 02:29 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
their is some debate on which spot is better.
most say its better to put the probe in the drivers side manifold.
it is a more accurate reading than the downpipe.
look into to cheap mods like the AIH delete and zoodad mods as well.
but exhaust intake chip and gauges are pretty much the start of a modiction.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #10 of 12 Old 08-01-2013, 02:48 PM
If you want accuracy, put it in the manifold pre up-pipe.
If you want easy install, put it in the down pipe. You can even buy a pre-tapped clamp so you only have to drill a hole in the exhaust.
I'd go in the manifold.
2001 F-250 XLT
6637 air filter, zoodad w/ custom enclosure, 4" TB straight pipe w/ 5" tip, water injection, PHP hydra-chip, boost, EGT & trans temp gauges, Sonnax valve tricumulator kit, AIH delete, foil delete, external IC/TC water mist spray
Troponin is offline
