Fuel pumps - Ford Powerstroke Diesel Forum
post #1 of 37 Old 07-24-2013, 08:02 AM Thread Starter
Fuel pumps
Fuel pump went out on 02' 7.3 other than replacing with OE what are my other options
Strokemaster02 is offline
post #2 of 37 Old 07-24-2013, 08:45 AM
Countryboy_7.3's Avatar
The walboro GSL392 is an option but it isn't nearly as reliable as a stock fuel pump. It can be a good pump but in my opinion you would want to have good fuel filtration before it got to your pump. If your truck is mostly stock stick with a stock pump.
-2002 f350 7.3L diesel
-20x12 fuel hostages, 325/50r20 atz's
-05 grille, bull bar, recon lights
-BTS
-Garrett 38r
-5inch straight pipe to 7inch fte black stack
-Full force 210/100
-Adrenaline hpop
-Hydra chip from PHP
Countryboy_7.3 is offline
post #3 of 37 Old 07-24-2013, 08:54 AM Thread Starter
It has a Pre filter b4 pump removed screens in tank and replaced with frame mounted Baldwin
post #4 of 37 Old 07-25-2013, 04:13 PM
ricochetbuell's Avatar
This was suggested to me from a fellow forum member last week when my stocker died- New Premium High Performance Fuel Pump Ford Pickup Van 7 3L Diesel E2236 | eBay
Working good so far and a lot cheaper then any other place I could find.
2001 F250 Crew Cab Short Box, 4" Pro Comp Suspension Lift, Banks 4" TB Exhaust with Banks Power Elbow, DIY Intake, Banks Big Head, Upgraded Lights, Monotube Adjustable Shocks, Guages, Toyo M/Ts , CCV Mod, A/C Mod, Foil Delete, AIH Delete, Zoodad, Dinger Delete, Hutched and Harpooned, ISSPRO gauges, PHP Phoenix
ricochetbuell is offline
post #5 of 37 Old 07-26-2013, 06:00 AM Thread Starter
I will stick with the Walbro I have run that pump and like it but was looking for other suggestion tan stock,Walbro
Thanx guys
post #6 of 37 Old 07-26-2013, 09:13 PM
CSIPSD's Avatar
Walbro equals 100% crap... Why pay $100 for a junk pump that is not rated for diesel use...
Here is an OEM replacement for only a few bucks more...
Riffraff Diesel: Bosch Electric Fuel Pump
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 37 Old 07-29-2013, 09:55 PM
the1laf's Avatar
What are you actually looking to do? just replace the pump with a reliable alternative or is this an excuse to upgrade your fuel system?
If you're just looking for replacement I agree with Joe, Bosch is hard to beat.
I personally would get rid of the fuel bowl and have some more filtration... I have the competition setup from Jake @ IDP but there's a more stock friendly kit that he offers. Buy Online | Irate Diesel Performance LLC
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #8 of 37 Old 08-14-2013, 11:18 PM
Ramsmoker's Avatar
Walbro
Walbro pumps are far from junk. If you want to burn more of your fuel and eliminate vapor, you need to raise the pressure. The OEM pump doesn't do well at this. I have a scrap barrel with my old ones and have never looked back.
The Ex -box. Total RSD system. See what happens when you let attorneys run your Country!!!! There's nothing wrong with a Democratic society, we just need to get rid of Democrats. 2001 Excursion. 2003 Cobra Terminator all pumped up. Now this is fuuuuuun.
Ramsmoker is offline
post #9 of 37 Old 08-14-2013, 11:21 PM
CSIPSD's Avatar
The Walbro does NOTHING better then the stock pump.
Vapor? Really? are we back to comparing gas to diesel?
The Walbro pump is not rated for diesel. It will not last.
I have a scrap bin of Walbros at home, 4 of them now...
Know how many stock pumps I have killed... NONE.
Joe
CSIPSD is offline
post #10 of 37 Old 08-15-2013, 08:03 AM
timmyboy76's Avatar
There was just a 6mon update on this pump...(another forum thread) Guy running wvo through it, so far so good..
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
