ww2 install - Ford Powerstroke Diesel Forum
post #1 of 24 Old 07-22-2013, 03:53 PM Thread Starter
ww2 install
I just ordered a wicked wheel 2 and im wanting to try to install it myself, I want to pull the turbo and tighten the wheel with a wrench instead of an impact, I am not a mechanic but i think I can do it, does anybody have a vid or a link to one that shows how to pull the turbo and reinstall? all i can find is people using an impact and i dont want to risk my impeller shaft any input would be apreciated, I would like to start pulling my turbo out tomorrow after work...
STECKSTROKE1999 is offline
post #2 of 24 Old 07-22-2013, 04:12 PM
Quoted: 17 Post(s)
Feedback Score: 3 reviews
it's not that bad, just aggravating because you can't get in a comfortable position. i took my front tires off and lowered the truck as much as i could so i could reach it better. you do not have to remove the "Y" pipe. everybody told me that you did but i was able to get the turbo out. the exhaust and hot side clamps are a pain in the butt(i would soak them in penetrating oil for a couple of days before). i would go ahead and pull the pedestal and do o-rings while you are that far into it.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 24 Old 07-22-2013, 06:00 PM Thread Starter
ill have to look into that, should i do anything with the wastegate?
post #4 of 24 Old 07-22-2013, 06:04 PM Thread Starter
also gomer is the wheel over rated? what gains are you seeing and have you had any issues?
post #5 of 24 Old 07-22-2013, 06:16 PM
Quoted: 17 Post(s)
I did it to get rid of surge. The gains weren't what i expected but there were some
post #6 of 24 Old 07-23-2013, 10:50 AM
http://www.dieselsite.com/pdffiles/ww.pdf
I used these directions from Diesel Site and they were spot on. Def soak the clamps for a couple days in advance.
I agree with Gomer...slight gain in performance, but no more surge
Ahuster is offline
post #7 of 24 Old 07-23-2013, 11:22 AM
blue99stroker's Avatar
Quoted: 289 Post(s)
you can take the wastegate off once you get the turbo out.
much easier than trying to remove it in the truck.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #8 of 24 Old 07-23-2013, 12:55 PM Thread Starter
I meant should i modify the wastegate in any way, and what psi are you seeing i have the bigboost and i max out at 25 psi that guy said he was getting 43 psi with the wheel
post #9 of 24 Old 07-23-2013, 12:58 PM
Quoted: 289 Post(s)
you can try and shorten the rod by turning it.
that might make it hold a little longer before opening.
ive gotten like 33 psi with my riffraff billet wheel.
pretty similar to the ww2 so with a good chip you should see around their.
and the 43 psi was with stage 1 single shot injectors. more fuel = more air.
post #10 of 24 Old 07-23-2013, 02:26 PM
Quoted: 17 Post(s)
I get mid 30s now. I did have to order a boost fooler to get above 25
