Are these necessary mods? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 07-19-2013, 02:51 PM Thread Starter
Thinking about ordering the following parts and wanted to get opions on necessity and if anyone noticed a difference with any of them.
FRX(RR)
HPX (RR)
CCV relocate kit (RR)
Intake Plenums (RR)
Intercooler Boots (RR)
Intake manifold (AFE)
Overboost Annihilator (RR)
already have 4" turbo back, egt\boost\pyro gauges, airaid intake.
Thanks,
csim1984 is offline
post #2 of 23 Old 07-19-2013, 03:18 PM
All those things are nice mods to have, but I would get a tymar or other intake instead of the air raid ASAP. Air raid/banks/k and n, and a lot of others use 2 ply filters that sacrifice filtration for flow and are known to dust turbos. Do a search for suggested intakes and see what you like. Also, when you buy your stuff make sure you use a site sponsor!
Moto2four is offline
post #3 of 23 Old 07-19-2013, 05:52 PM
FRX(RR) might help quiet motor, helps keep air from passing through the injectors because of the dead head fuel rail
HPX (RR) kind of the same as frx but for oil
CCV relocate kit (RR) helps keep boots cleaner and helps prolong the life of the boots
Intake Plenums (RR) not necessary unless you are having issues with stock
Intercooler Boots (RR) if your boots are bad or worn out
Intake manifold (AFE) no benefits imo. Spend money on something more important
Overboost Annihilator (RR) not needed, good tunes will eliminate the need
Thanks,
What are your goals? Do you have a chip? As mentioned, might be nice to have some of these but not needed.
I would honestly spend money elsewhere. Frx and hpx would be the ones on this list I would buy depending on overall goals.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #4 of 23 Old 07-25-2013, 12:14 PM Thread Starter
Thanks for the info. ill look into the 6637 DIY but i dont know where my stock peices are anymore...
As far as goals i use this as my daily and plan to tow 30' toy hauler. I am going to order the PHP Phoenix 6 pos (this clears overboost?).
Thanks,
csim1984 is offline
post #5 of 23 Old 07-25-2013, 01:35 PM
c69ss396's Avatar
INFRNL Pretty much covered it...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #6 of 23 Old 07-25-2013, 05:32 PM
hansel's Avatar
Quoted: 100 Post(s)
What he said, but I will defend the Airaid filter kit. I've had one for over 12yrs and over 230,000 miles with out a issue of dusting, in fact they (airaid) replaced the filter "free" because they have a 1 million mile warrenty.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #7 of 23 Old 07-25-2013, 09:29 PM
Quoted: 14 Post(s)
6637's are cheap and very effective. No sure why anyone would use anything else.
ttyR2 is offline
post #8 of 23 Old 07-26-2013, 03:33 AM
Quoted: 18 Post(s)
Send a message via AIM to rufushusky
FRX(RR)
HPX (RR)
Intake Plenums (RR)
Thanks,
Are any mods on a 7.3 really that NECESSARY? IMHO no, literally millions of them (between the PSD and the T444E) ran full service lives w/o the need for any mods at all.
Now non of those mods are going to hurt at all. I would can the intake manifold, the cost vs. benefit isn't there IMHO. I would add a hutch mod to that list while your at it.
Welcome to guzzle's In-tank Hutch Mod Web Page
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #9 of 23 Old 07-26-2013, 07:08 AM
timmyboy76's Avatar
Unless you route the ccv into a catch can, and re-plum, back into the air intake, you'll be disappointed. The smell it puts off, especially at idle/stoplight..etc, is just plain awful.
Had mine opened to atmosphere, and it lasted about a week, and went back to stock.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #10 of 23 Old 07-27-2013, 05:54 AM
Just curious. Do you or will you periodically "clean" the intake system to keep oil from settling in the boots? I was thinking about doing this mod but have talked myself out of it. I do have oil visible on the passenger side plenum, could that oil be traveling from the CCV or could it be the seal around the bottom of the plenum. Both plenums area oily/dirty along with their boots. I am going to put on a new set of boots in the near future and maybe a set of plenums.
Paul
01 F350 CC 4 x 4 LWB, not running yet.
SOLD...03 f250 CC 4x4
PHP Hydra, AIS w/fender sleeve, Magna Flow 4" Dual Exh, Warn Premium Hubs, Skyjacker Leveling Kit, CTS Insight for monitoring, Ranch Hand GG, Riff Raff boots, Riff Raff IAH Delete, Riff Raff HPX, Riff Raff FRX, Foil Delete, CCV Mod
trlrdrinla is offline
