Hybrid Injector Fuel System? - Ford Powerstroke Diesel Forum
post #1 of 33 Old 07-15-2013, 05:54 PM Thread Starter
smokenstroke's Avatar
Quoted: 8 Post(s)
From those with experience in tuning and/ or running hybrid injectors, has anyone tried to run the smaller hybrids 205-238cc range with a stock superduty fuel system? Can a completely stock fuel system keep up with a 205/100 injector? i ask this question because with a pmr motor i feel you are going to be limited with the rods before you are limited with fuel. If a stock fuel/ oil system will feed a 205/100 with no issues in a "safe" tune for pmrs that seems like the best way to go. Any opinions??? I've got the air flowing and ready to send some fuel with it.
Thanks
2002 F250
Tunes
Intake
Exhaust
Turbo
Injectors
Traction Bars
smokenstroke is offline
post #2 of 33 Old 07-15-2013, 05:58 PM
01Crewcab7.3's Avatar
Thanks
I could be wrong here but I think that once you go past 160/100's it is recommended to at least build a twin SD pump fuel system. Marty has a write up in the tech section with great details.
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 33 Old 07-15-2013, 06:00 PM
As long as you can keep the pressure up, you would be fine. I do not have a definite answer and I run a full upgraded fuel system for my 250/100s.
I want to say a single stock pump will not be able to keep up, but im not certain either
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #4 of 33 Old 07-15-2013, 06:02 PM Thread Starter
Quoted: 8 Post(s)
Im sure the tunes wrote wont be requesting full fueling or a long pw. thats the only reason i think it would keep up.
2002 F250
Tunes
Intake
Exhaust
Turbo
Injectors
Traction Bars
post #5 of 33 Old 07-15-2013, 06:04 PM Thread Starter
Quoted: 8 Post(s)
Im stuck between a 160/100 or go with a 205/100. I want the larger nozzle to shorten pulse width. From what everyone is saying now thats the key to keeping cylinder pressure down. Its just the hybrid is going to require less oil and they are only about $200 more and do have a little more room to grow.
2002 F250
Tunes
Intake
Exhaust
Turbo
Injectors
Traction Bars
post #6 of 33 Old 07-15-2013, 06:05 PM Thread Starter
Quoted: 8 Post(s)
So i assume you are still on a stock pmr bottom end?
2002 F250
Tunes
Intake
Exhaust
Turbo
Injectors
Traction Bars
post #7 of 33 Old 07-15-2013, 06:07 PM
You would be surprised how much fuel you need when wot. I actually retract what I said earlier.
My stock pump, using an frx with tunes on stock injectors and turbo had a hard time. Would not hold steady pressure under wot but did not drop below 50psi.
Stock motor, 200k pushing close to 500hp from what im told. Never been on a dyno.
INFRNL is offline
post #8 of 33 Old 07-15-2013, 06:18 PM
If it were me I would just get a set of 238/100's, and do a DIY fuel system including a bowl delete and RR and call it a day.
Tim
post #9 of 33 Old 07-15-2013, 06:31 PM Thread Starter
Quoted: 8 Post(s)
There are multiple trucks that run over what I'm wanting to do with the stock fuel bowl and no rr. Just a larger pump set-up
2002 F250
Tunes
Intake
Exhaust
Turbo
Injectors
Traction Bars
post #10 of 33 Old 07-15-2013, 06:36 PM
Not trying to be a d*ck here but you seem to already have the answers you are looking for. Why make the post?
Tim
