best place for guages???? - Ford Powerstroke Diesel Forum
post #1 of 34 Old 07-14-2013, 11:33 AM Thread Starter
metalman7.3's Avatar
Hey Im thinkin of getting some guages for my truck, trans temp, EGT and boost, I'm wondering where the best palce to put them is??
Im thinkin of doin the pillar but i think it looks to race car-y, any one have guages on the pillar, wheres the most convienient place to put them??
2002 f350 7.3 auto
tan on black,
flat bed
cold air intake
TS 6 pos. chip
metalman7.3 is offline
post #2 of 34 Old 07-14-2013, 11:54 AM
01Crewcab7.3's Avatar
The pillar is the most common and in my opinion, the most convenient.
I, along with most people, recommend ISSPRO EV2 gauges. They are pricey, but you cannot beat the quality. I believe throroughbred diesel has the cheapest price on a kit.
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 34 Old 07-14-2013, 11:57 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'd say that if someone gets analog gauges... 90% of the time it's on the A-pillar. Simply because having the gauges at a location where you can quickly glance at them and look back to the road is key! Some guys put them around the steering column, above the rear view mirror, or mounted somewhere in the dash.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 34 Old 07-14-2013, 12:13 PM
Colin7.3's Avatar
Riff raff has the f650 dash upgrade you can put in and have your gauges there
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #5 of 34 Old 07-14-2013, 12:50 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Pillar.
But if I do it again, no analog gauges. Waste of time and money. Gonna go with a digital monitor.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 34 Old 07-14-2013, 01:30 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
I don't like the pillar either....
Besides looking "too race car-y" for a grown mans truck (I avoid anything that reminds me of "ricer" - windshield graphics/ 7" tailpipe/ 6637 filter/ that kind of stuff), it blocks your vision some. I chose over-the-mirror, bought IssPro from kensperformance. It came as a package gauges/pod/paint & primer and I couldn't be happier with it
NoRalPh is offline
post #7 of 34 Old 07-14-2013, 01:48 PM
Quoted: 8 Post(s)
Originally Posted by jesilvas View Post
Pillar.
Definetly best bang for you're buck!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #8 of 34 Old 07-14-2013, 03:37 PM
Quoted: 157 Post(s)
I completely disagree...
Digital monitors are bling for the App-Happy who know Much less than they should about this stuff They're neither Fish nor Fowl. They try to do everything but end-up doing a poor job of it All.
They're poor gauges (relying on the PCM's sensors for the most part. If you add real sensors the cost skyrockets), they are Not as easy to read unless you dedicate the entire display to just one gauge (dividing-up the screen makes them too small). They may give you a warm & fuzzy because you can monitor so many things but, they're mostly unimportant like pulse width, vacuum, and the like. GET REAL GAUGES AND SENSORS IF YOU WANT ACCURATE & MEANINGFUL READINGS!!!
They're a poor scanner with limited diagnostic capabilities and again, give you a feeling of false security in your diagnostic abilities. GET A REAL SCANNER TO HELP YOU DIAGNOSE YOUR TRUCK!!!
They, for the most part, contain poor "canned" programming/tuning. GET REAL TUNING FOR SAFE & PROPER PERFORMANCE OF YOUR ENGINE / TRANSMISSION!!!
There is NO FREE LUNCH, you save Very little with something like the EDGE once you add Pyro & Trans sensors. REAL Gauges-Tuning-AutoEnginuity is gonna run around $1,000. Buy it as you can afford it, the difference will be the best money you spend in the end because you'll have what you should have to do the job right
IMHO....
NoRalPh is offline
post #9 of 34 Old 07-14-2013, 04:05 PM
Quoted: 8 Post(s)
IMHO....
If you can justify spending over a $1000 on gauges… go for it! I'd rather not have to tap into wiring harnesses (FICM voltage, VGT cycle, icp volts, IPR duty cycle). Not to mention that at all times I'm monitoring 8 gauges at the same time… show me pics of your analog gauge set up monitor 8 gauges and I'll be impressed… and laugh at your wasted time and money! Vehicles that are used as race vehicles can easily justify running $1000+ for gauges but a street driven truck. Ummmmmm….no!
Yes I understand that the ecm gives false readings on a few sensors because of a certain tune, but that doesn't mean that all readings are inaccurate. There is not many people that spend the kind of money you are talking about for analog gauges. The number one reason to get a monitor is so you can monitor ECT, EOT, FICM and so on. The readings a monitor gives is pretty dam accurate… only ones I can think that are NOT accurate are icp(when tuned) and boost numbers and all the other digital gauges are more than acceptable for the average Joe!
But then again… I like to feel all warm and fuzzy hahah
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #10 of 34 Old 07-14-2013, 04:28 PM
jesilvas's Avatar
Quoted: 2 Post(s)
OEM sensors are real sensors. If they aren't reading right, there is an issue, that needs be addressed, and it's a good thing it was being monitored. If the monitor is getting bad readings, that means the PCM is also, and is not fueling properly.
4R100, 2wd
330,000 + miles
jesilvas is offline
