hpx line removal - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-13-2013, 01:15 PM Thread Starter
aint no f ing hemi's Avatar
hpx line removal
i had to remove the hpx line i got from strictly diesel to make room for the turbo to come out. after re installing it, i started dumping oil. anyone else remove it and have leak issues after reinstall? if so, how did you fix it? thanks in advance.
1999.5 f250 auto 4x4 cc long bed
diy intake
ccv mod
18k mod
zoodad mod
aint no f ing hemi is offline
post #2 of 5 Old 07-13-2013, 02:14 PM
timmyboy76's Avatar
if its anything like riffraffs, the turbo CAN be snorkeled around the hpx, so for it to not to be removed. Get back in there and re-tighten ur down, or is it leaking at the base? Maybe new orings are in order..#5
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 5 Old 07-13-2013, 07:07 PM Thread Starter
i must have been mistaken. i took it all apart a second time, cleaned the hpx fittings and replaced the rubber o rings with copper washers, put it back together, and ran the truck. it still leaks but there's no oil on the copper washers. it must be the o rings on the turbo. mother f-er
diy intake
ccv mod
18k mod
zoodad mod
post #4 of 5 Old 07-15-2013, 08:56 PM
timmyboy76's Avatar
how are you getting the copper washer to seal and not leak, since the head in "bossed" for an oring for that #5 bolt? Also, you'd see it leak from the HPx while idling.
post #5 of 5 Old 07-16-2013, 03:16 PM Thread Starter
the copper washer i have is thicker than the o ring so it puts plenty of tension on it. beyond that i don't know, it just ain't leaking
diy intake
ccv mod
18k mod
zoodad mod
