Using My Spartan 6.4 Dashdaq To Monitor Parameters On My 7.3 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-10-2013, 08:06 PM Thread Starter
Powerstroke Man 6.4's Avatar
Been searching around didn't find any threads like this just like the title says can I use my 6.4 spartan diesel tech dash daq only to monitor parameters like basic IPC IPR ECT EOT etc on my 7.3 ? Also if it is possible will it mess up my tuning for my 6.4 ? Thanks for your guys help advance
2012 Ford F-350 SRW 3.55 LS Lariat Blk Crew Cab Spartan 200 Hp Tune Warhammered 5 In MBRP EX AFe S 2 CAI
2008 Ford F-350 White XLT Crew Cab DRW
MPRP 4 IN Downpipe Back DPF Cat Delete Stright Pipe Spartan 300 LL Tune AFe ST 2 CAI MBRP 3 IN Intercooler Pipe. 4.30 LS
Late 1999 Ford F-250 XLT X-tra Cab White 7.3 SRW 6637 MBRP 4 IN Turbo Back Exhaust No Muffler DP-Tuner And PHP Hydra T-500 Swamps 160/100% Inj Airdog Swamps HVHF IDM GTP38R W WW2 305,000 MI 3.73 Non LS
Powerstroke Man 6.4 is offline
post #2 of 7 Old 07-10-2013, 09:20 PM Thread Starter
Anybody ???
post #3 of 7 Old 07-11-2013, 08:28 PM
Joel's Avatar
Quoted: 10 Post(s)
Why not plug it in and find out?
Im guessing it will say that is VIN locked to the other truck and not work.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 7 Old 07-12-2013, 09:45 AM
Justin@DP-Tuner's Avatar
Quoted: 54 Post(s)
Yes, it should work. Locking the VIN only has to do with the tuning aspect. You should be able to plug it in to any OBDII vehicle and monitor data.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #5 of 7 Old 07-12-2013, 06:22 PM
Joel's Avatar
Quoted: 10 Post(s)
Ok now you HAVE to plug it in and tell us
Joel is offline
post #6 of 7 Old 10-21-2013, 10:33 PM Thread Starter
:Update:
So I finally put the spartan dashdaq on the 7.3. The dashdaq can read 254 PIDS on the 7.3 PCM (With the ford advance PIDS package only) The spartan Dashdaq can only read 20 ford specific PIDS. EOT TFT ICP TQ RPM and (15 other PIDS don't remember them though.)(Read clear codes). (The Spartan Dashdaq is not equipped with the Ford advance PIDS package unfortunately unless you tell Spartan to add it on for you so it cant read the other 234 PIDS on the 7.3 PCM.)
post #7 of 7 Old 10-22-2013, 09:04 AM
SeeYa's Avatar
Originally Posted by Powerstroke Man 6.4 View Post
:Update:
You can go to Drewtech's website and buy the Ford Advanced PIDS and it will work. Although, you can't have generic, ford Enhanced and UDS on the unit at the same time. All pre-configured gauges Spartan did on it originally will be lost.
OR you could have us convert the Spartan to the INFINITY. Afterwards you won't be able to use it on a 6.7 and you will lose everything Spartan had on it. You will need to contact us for converting prices.
Let us know if we can help.
~Diane
Custom Tuning-Computer Chips
Flash Programmers-Aftermarket parts
Ford Power Stroke Engine and Transmission Tuning Specialist since 2004.
828-221-0076
SeeYa is offline
