Need help deciding on new 7.3 injectors - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-30-2013, 07:43 PM Thread Starter
RickyVaughn33's Avatar
It has come to my attention that I have a few injectors that are going out and I need some help in deciding what kind of injectors to get. I have a 01 f250 6 speed. The truck is used to haul hay and cows, sometimes across the country. I have thought about stage ones just because of a slight power and efficiency increase. My motor is also bored 30 over. The truck has a 4 inch turbo back exhaust and that is the only mod I have done. I need to get a new set of injectors and need to know what kind of injectors to go with and who to get them from. I don't want to go crazy and dump a ton of money, but I do want a modest increase in performance for when I'm pulling heavy loads. Thanks in advance for any insight.
01 F250 6 speed 143k
4 inch turbo back MBRP straight pipe
6637 intake
quad gauge pod
bored 30 over
ranch hand bumpers
Swamp's 175/146 stage 1 injectors
Custom Tuned TS 6 Position
RickyVaughn33 is offline
post #2 of 10 Old 06-30-2013, 09:44 PM
Many will say to go with stage 1 injectors if needing new injectors.
If you go with stage 1 injectors you will need a ts style chip with custom tunes or a dp tuner chip. But you must have at least an exhaust gas temp guage when running a chip. You do not really want your egts to get higher than 1200-1250 degs unless it is for a very short time. Most prefer to keep it at 1250 or lower.
I also have a set of stock injectors if you are interested, then you could just get a chip and egt guage. Its really up to you.
If you get injectors look at fullforce diesel for casserly injectors, PIS injectors or Jim rosewood injectors. Swamps injectors are also good
Really depends on how much you are willing to spend. If you are just looking for some added power a chip will make a huge difference. I personally prefer PHP tunes, but there are other good tunes out there from Tony Wildman, No Limit (Beans), Gearhead, Swamps or DP
DP can only be run on their chips. The others listed can all be used on the TS style chip if you wanted to explore, but that involves more money.
I honestly think PHP offers the best bang for the buck and have some of the best tunes available IMO
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 10 Old 06-30-2013, 10:38 PM
CSIPSD's Avatar
Gauges...
AC's or Stage 1 injectors with 100% nozzle.
Injectors from P.I.S, talk to Tim about what you want.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 10 Old 07-02-2013, 11:23 AM
dentexpowerstroke's Avatar
Originally Posted by CSIPSD View Post
Gauges...
Joe beat me to it... Tim is a great guy to deal with, he's the only one ill go to for injectors now.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #5 of 10 Old 07-09-2013, 01:25 PM
Stroker7.3's Avatar
Swamps stage 1 single shots. They really get the job done are affordable and have an excellent warranty.
2000 FORD F250 SUPERDUTY
Stroker7.3 is offline
post #6 of 10 Old 07-10-2013, 05:43 AM
rascal's Avatar
Who is P.I.S?
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #7 of 10 Old 07-10-2013, 10:42 AM
performance injection systems
Not sure who they are exactly but heard great things bout their injectors, customer service, etc
INFRNL is offline
post #8 of 10 Old 07-10-2013, 10:34 PM
CSIPSD's Avatar
Tim is by far the most informative guys I have dealt with in the last few years.
Joe
CSIPSD is offline
post #9 of 10 Old 07-11-2013, 08:11 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Get Full Force's...been building Inj's for a long time. better warranty and price. We are a dealer..PM me if I can help.
CT Performance, Inc. is offline
post #10 of 10 Old 07-14-2013, 12:47 PM
My set up hauls and has minimal smoke.
I beat a buddies raptor the other day by a truck length.
Towing 12k up hills is a breeze.
Make sure your up pipes are not leaking, that one fix made everything come together! The spool up is awesome, from 15-35psi is quick!
01 F-350 reg cab srw 7.3
Important stuff:
Beans stage 1 injectors, Beans 6 position chip
Dieselsite ww2, boost fooler, wastegate controller
gauges, upgraded up pipes,
afe intake, 4" flow through muf w/turn out
BTS transmission, 6.0 cuuuler
35"toyo mt on 18" black kmc addicts
06 F-350 cc srw 6.0 lariat
build being planned...starting with the cab off
frashdog is offline
