The best top 10 mods for a 7.3 - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 25 Old 06-25-2013, 10:02 AM Thread Starter
Looking through the post and alot of guys are always looking for mods to there trucks. I though it would be a good idea to start a list of your top ten mods to the 7.3 and drive line. It can be anything from making the truck run better to all out power.
Let see what you guys come up with.
greg64 is offline
post #2 of 25 Old 06-25-2013, 10:29 AM
ThomasvillePavers's Avatar
IMO
1.) 6637 filter
2.) 4" turbo back exhaust
3.) Electric A/C condensor fan (I live in south Georgia and its HOT here)
4.) Window tint
5.) Tuner with digital gauges (SCT livewire TS or Infiniti-DX)
6.) Door lock actuator mod (because they are gonna act up)
7.) 05'+ headlamp upgrade
8.) Turbo surge fix (Wicked wheel, ported housing or turbo upgrade)
9.) PSI fooler if not built into tuner/chip
10.) Harpoon mod if you put the miles on quickly
Of course all of these are AFTER standard maintenance and service!
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #3 of 25 Old 06-25-2013, 12:43 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
I think what you're gonna get is, the 10 things anyone did (I have no idea what the guy above me is thinking....) hehehe
For ME it's;
1) JW Valvebody
2) 6.0 Trans Cooler
3) AIS filter
4) 4" SS Exhaust (w/straight-thru Muffler)
5) WickedWheel (for the Whistle if nothing else )
6) FRX & HPX
7) Hutch & Harpoon
8) PHP Tunes (those All-in-Ones SUCK!)
9) 200psi Train Horns (daytime weapon!)
10) 180w LED LightBar (nighttime weapon!)
Anyway,,, that's my truck and the things I did, and am the Happiest with!
NoRalPh is offline
post #4 of 25 Old 06-25-2013, 02:01 PM
OP
My list is not the first 10 items I did but my biggest issues/desires with the superduty 7.3 platform in general...
I can re write my list for engine/drivetrain specific if you would like.
-Brad
post #5 of 25 Old 06-25-2013, 02:03 PM
corn binder's Avatar
Quoted: 2 Post(s)
2) d/p& full exhaust
3)wicked wheel
4) gauges
5) upgrade tranny cooler
6)boost fooler
7) stage 1 inj's
8) php or tony Wildman tunes
9)billet converter
10) sd hpop& lines
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
post #6 of 25 Old 07-08-2013, 08:39 AM
jacobm24's Avatar
For ME it's;
1) JW Valvebody
2) 6.0 Trans Cooler
3) AIS filter
5) WickedWheel (for the Whistle if nothing else )6) FRX & HPX
7) Hutch & Harpoon
Anyway,,,
lol! I agree with 5 and am now adding 9 & 10 to my list of must do's!
2000 f250 7.3 w/ 103k miles
4" MBRP turbo back exhaust
DIY Intake with AFE big boost filter
Autometer Cobalt gauges (trans, boost,pyro)
PHP Phoenix stock, 40ht,80dd,120race
Wicked Wheel
Harpoon Mod
203* thermostat
Dieselsite coolant filter
Dieselsite IC Boots
Fightin' Texas Aggie Class of 2013!
Petroleum Engineering
jacobm24 is offline
post #7 of 25 Old 07-08-2013, 06:36 PM
hansel's Avatar
Quoted: 97 Post(s)
Let's see
1) Air filter upgrade
2) Exhaust opened up
3) 6.0L trans. cooler
4) EGT,Trans temp gauges
5) PHP Hydra chip
6) Window's tinted
7) Cool looking tires
8) Delete the foil (sounds really cool)
9) Kick arsh Bass stereo system
10) A 5th wheel or Travel Trailer
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #8 of 25 Old 07-11-2013, 12:16 AM
importedaze300's Avatar
1. bts valve body
2. 6637 intake
3. 38r
4. wastegate controller set to approx. 23psi
5. mrbp 5" exhaust
6. ts chip
7. oil balance line
wanted
8. stage 2 injectors
9. cfm intake manifold
10. over/under gear
6637 filter
5" exhaust
bts valve body
gtp38r
no ebvp pedestal and exhaust outlet
oil feed line cross over
ts 6 position chip
6" lift
20" fuel wheels on 35s
2x4 to 4x4 conversion
2001 supercab 4x4 manual no mods
importedaze300 is offline
post #9 of 25 Old 07-11-2013, 12:47 AM
alaskan155's Avatar
Quoted: 60 Post(s)
no specific order
1. 285s
2. explorer a/c bypass mod(need to replace condenser, but it works nicely)
3. rotella ELC
4. pioneer 4000 with 3-ways in all 4 corners(had it from old f150)
5. topper(sleep in the back sometimes)
6. around belt upper radiator hose(must do for all 7.3s)
sure my list will change the longer i own it, have had it since april now.
think the led light bar and mbrp turbo back are on my list of wants, if not a few more things
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #10 of 25 Old 07-11-2013, 04:20 AM
Jerrybizzle's Avatar
Quoted: 24 Post(s)
This is what I've done and its not quite ten, but I'm getting there.
1. 6637 intake
2. 4 inch exhaust
3. Gauges
4. Chip
5. Wheels/tires which happened to already be on truck when I got it
6. Transmission cooler (want item at this point)
And that's it for now.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
