Turbo or injectors? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-22-2013, 07:15 PM Thread Starter
Turbo or injectors?
what would you guys do, Upgraded garret 38rturbo or stage one injectors and which would give you the better power?
smoke on this is offline
post #2 of 7 Old 06-22-2013, 07:31 PM
Macon's Avatar
Great question.
I plan on turbo before injectors. Stock sticks can supply more fuel than the stock turbo can feed. It makes the decision easy for me. No matter what you do, you'll need custom tunes to fit. You HAVE to get custom tunes for single shot injectors, so be sure to add that to your budget. Tunes aren't needed for a new turbo, but, if you are going well outside the factory specs, your performance will suffer, so plan for new tunes.
I smart and/or rich man would plan and save for both at once, that way you only need to pay for custom tunes once. I'm neither, so I go for easiest first. I can change driving habits for a turbo. I can't go to the store with single shots.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 7 Old 06-22-2013, 07:40 PM Thread Starter
that's kinda what I figured and ordered the turbo, got a hydra chip from PSP ,with coldair intake beefed up trans with john wood valve body and a insight for gauges,should run good with turbo.
post #4 of 7 Old 06-22-2013, 07:46 PM
Macon's Avatar
Meh, what I plan and what's right don't always equal. Before you install the new turbo, wait for a few other folks to chime in that know better than I. I am simply planning with what I've experienced.
2002 F250 CCSB 4x4
Macon is offline
post #5 of 7 Old 06-22-2013, 07:49 PM
the1laf's Avatar
I'd go injectors first.. Unless you're set on stage 1's I'd go with stage 2's.. you can have them tuned for most potential of your stock turbo without burning it up.. Then someday if you feel like upgrading the turbo you'll have enough fuel. You'll have better low end response and torque.
With the correct housing the 38r will be better all the way around.. spooling, boost, etc. But with the wrong housing it will be laggy, Even with your oem injectors maxed you won't have reached the full potential of the 38r.
Someone should chime in with a little more personal experience with both.
I'm planning on running Stage 3 250/200's for about a year before i can afford an H2e so this is just my two cents..
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #6 of 7 Old 06-22-2013, 07:59 PM
the1laf's Avatar
Macon has a good point, you have to include the tunes with injectors, not to mention gauges.
If you're planning on only one or the other the turbo should be chosen..
If you're trying to add one part a year like I am then you can run detuned injectors until you can afford a turbo without adverse results.
the1laf is offline
post #7 of 7 Old 06-26-2013, 11:18 PM
Should have went with injectors first, but both would be the best option if possible.
Stock injectors with bigger turbo, you will most likely not see much gain.
However if you just do injectors and get your custom tunes, they will need to be refined for the new turbo as well. Its like a catch22. This is exactly why I did injectors and turbo at the same time. However in my case, I still need fine tuning and had 3 revisions on my tunes to get where I am at now.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
