Ok I know this thing does no good but do you think it has damaged my motor? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-17-2013, 08:54 PM Thread Starter
This was on the truck I just bought, the owner didnt say how long it has been on there and i did not see it when I was looking at the truck because it was tucked under the air box.
I am going to take it off immediately but my question is do you guys think it could of done any damage?
The truck runs good and doesnt make any abnormal noises or anything
wannatruck is offline
post #2 of 16 Old 06-17-2013, 10:44 PM
CSIPSD's Avatar
More then likely its just an ICP mod... Where is it wired to?
I see no reason to remove it right now, better to have gauges, but its only an ICP mod.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 16 Old 06-17-2013, 10:58 PM Thread Starter
Its wired to the iac, I read up on it that it has caused some engine damage to a few cummins guys, but the never go into detail as to what the damage is. so I dont know the accuracy of that
post #4 of 16 Old 06-17-2013, 11:49 PM
CSIPSD's Avatar
Huh? Its wired to the intake air temp? If its wired to the intake air temp then its not doing a damn thing, because the PCM will not change anything based on the intake air temp.
Post a picture of what its wired to.
Joe
CSIPSD is offline
post #5 of 16 Old 06-18-2013, 12:13 AM
Quoted: 728 Post(s)
IAC=Idle Air Control
not intake air temp
Corey@CNCFAB is offline
post #6 of 16 Old 06-18-2013, 12:21 AM
CSIPSD's Avatar
There is no Idle Air Control on a 7.3... Which is why I asked the question...
There is an ICP sensor, which is where that box is more then likely wired to, there is an intake air temp sensor (does nothing) and that's about it... There is really nothing else that box could go to, unless its running an EBPV (Exhaust Back Pressure Valve) exhaust brake.
Need a pic of where that box is wired to to tell you for sure.
Joe
CSIPSD is offline
post #7 of 16 Old 06-18-2013, 12:34 AM
Quoted: 728 Post(s)
Yes there is, just not on all models. Here's a pic of the location
post #8 of 16 Old 06-18-2013, 02:04 AM
CSIPSD's Avatar
LOL... thats the fuel bowl restriction sensor... Where do you come up with this crap?
And its only on the OBS models.
Joe
CSIPSD is offline
post #9 of 16 Old 06-18-2013, 02:09 AM
Quoted: 728 Post(s)
PCM most definitely makes changes due to IAT. This sensor is why you get worse MPGs in the winter vs summer. It is used to help determine the fuel tables for colder air (more oxygen since our trucks don't have 02 sensors to determine this).
post #10 of 16 Old 06-18-2013, 02:11 AM
Quoted: 728 Post(s)
Lol. Keeping you on your toes.
