Exhaust manifolds? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-15-2013, 05:15 AM Thread Starter
Exhaust manifolds?
Well, it seems we finally found the exhaust leak in the engine compartment - the passenger-side manifold appears to have a hole in it.
Before I let the mechanic just stick a stock manifold in there, are there any better choices? Better choices under $250 each, or $400 for a pair, because that's about all I'm spending on manifold(s), as I expect there will be substantial labor costs given how rusted the bolts look.
BrownianHeatingTech is offline
post #2 of 10 Old 06-15-2013, 10:39 AM
blue99stroker's Avatar
Quoted: 247 Post(s)
theirs only a few places that make headers, and they are about 1000 bucks...
thats why no one has them lol
ya any bolts in the exhaust system are a not very fun to get out. i hope he used lots of penetrating oil.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #3 of 10 Old 06-15-2013, 09:03 PM
rascal's Avatar
I recently had to replace the EBPV fitting on the front of the passenger manifold..what a B!TCH!
I soaked it with penetrating oil for a week; still would not budge. Ended up using a small torch and a candle. Came right out after 4 or 5 heat cycles.
Made me think how much of a pain in the @ss the headers would be if I ever went that route.
Good luck!
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #4 of 10 Old 08-15-2013, 12:04 AM
Ramsmoker's Avatar
Headers
They are expensive but nothing replaces what they do. I've heard the big numbers don't show the value. I guess if your a racer and the big numbers is all you want, do what you gotta do. Power band starts lower than 1500rpm, total turbo response throughout the power band is better. I saw fuel mileage improvement and a real loud turbo. For a daily driver, I can't find any down side. I have less smoke and better fuel mileage.
The Ex -box. Total RSD system. See what happens when you let attorneys run your Country!!!! There's nothing wrong with a Democratic society, we just need to get rid of Democrats. 2001 Excursion. 2003 Cobra Terminator all pumped up. Now this is fuuuuuun.
Ramsmoker is offline
post #5 of 10 Old 08-15-2013, 01:54 AM
CSIPSD's Avatar
Where do you come up with this chit man?
Headers are a total waste on all but a full build motor... Good lord
To the OP'er, get a set of coated factory manifolds and be done...
Riffraff Diesel: Ford Exhaust Manifold - Right 99-03
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 10 Old 08-15-2013, 04:48 AM Thread Starter
I ended up just getting the replacement manifold. Summit Racing had the best price. The unit was a Dorman, and both I and my mechanic were impressed by the quality; the machining was right up to OWM standards.
I bought the mounting bolts from the local Ford dealer, as I wanted to make 100% certain that those were right.
Also ended up replacing the up-pipe - when we removed the manifold, the up-pipe just fell out of the upper flange... the gasket was just gone. I would have preferred to do the bellowed up-pipe, but I wasn't about to tear apart half of the engine bay, right now. The factory unit went in with no additional disassembly. I also didn't want to wait to have one delivered, and the factory up-pipe was available at the dealer.
We ended up having to torch off the heads of all eight manifold bolts, and the two bolts that connect the manifold to the up-pipe. Then heated them red and sprayed them with penetrating oil. Came back in an hour and they actually came out smoothly with the extractor.
I installed the RiffRaff FRx that's been sitting on my shelf, and my own bypass oil filtration kit (similar to the "SpringerPop" design, but mounted differently) while he was working on the exhaust, so it was a pretty productive day. I like being on good terms with my mechanic, so I can use his shop and tools - fighting the fuel test plugs out of the heads with visegrips and such was going to be crazy, but if you actually have a 5/16" square socket, they come out with no more trouble than any other bolt.
post #7 of 10 Old 08-15-2013, 08:16 AM
timmyboy76's Avatar
RockAuto...#679005 / $180.00...More Information for DORMAN 679005
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #8 of 10 Old 08-15-2013, 08:56 AM
CSIPSD's Avatar
I use SS bolts for my manifolds... Easy cheasy removal.
Joe
CSIPSD is offline
post #9 of 10 Old 08-15-2013, 01:13 PM Thread Starter
From what I've understood, the bellowed up-pipes don't bolt to the factory wye connector on the turbo. So the whole mess needs to be removed in order to install the new wye. That was my understanding, anyway.
In any case, I needed it done, then, and couldn't wait for additional parts to be delivered.
post #10 of 10 Old 08-15-2013, 01:51 PM
Quoted: 247 Post(s)
new bellowed up pipes come with a new y pipe. its the hole shibang
