exhaust system upgrade question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-11-2013, 07:06 PM Thread Starter
I want to put a 4" turbo back exhaust system on my 2000 F350, but I don't want it to be any louder than the stock system. Is this possible? If so, what kit/muffler combo will give me the increased flow without increased noise? Thanks for any help.
Cobra Too is offline
post #2 of 9 Old 06-11-2013, 07:12 PM
aussie=effie
bob harris's Avatar
Smile exhaust upgrade
MBRP PERFORMANCE SYSTEM WORKS WELL FOR MY 99 7.3
bob harris is offline
post #3 of 9 Old 06-11-2013, 07:54 PM
1BADTON's Avatar
Have Banks installed by previous owner and truck cam from east coast, so exhaust looks pretty bad. Supposed to last?????? When I go for a new one it will be MBRP
1BADTON
01,Lariat CCLB, 7.3L, 8" Donahoe on 37"s, John woods, ARBs, 4:88, Hansen's frt&rear, 15k Warn, HID's, DP Tunr 80econo, banks cooler, adreniline, msd dpi, optima's, autometers, more to come?
1BADTON is offline
post #4 of 9 Old 06-11-2013, 08:18 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
These trucks are pretty loud stock anyway. Why not straight pipe it and squeeze all you can from your mod? Straight pipe isn't much louder than stock unless your romping on it (even then you can't hear much of a difference from inside the cab).
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #5 of 9 Old 06-12-2013, 04:34 AM Thread Starter
You are right in that the noise in the F350 is not exactly quiet, but that's exactly why I don't want to make it any louder if I can avoid it. I put a Magnaflow exhaust system on the F150 I used to own. The low frequency drone it added to the cab at tow speed on the highway drove me crazy. That's what I want to avoid.
post #6 of 9 Old 06-12-2013, 05:58 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
The MBRP muffler works pretty well. I'd say it is a bit louder when you get on it, but I too wanted to avoid the "drone" you can get from a straight pipe. There's little performance, if any, gained anyway between the two.
You can't compare the experience you had with your F150 gas engine, the Turbo takes out So Much of the engine noise already and is the reason you can even go with a straight pipe.
NoRalPh is online now
post #7 of 9 Old 06-27-2013, 03:46 PM Thread Starter
Just to report in. I put the Diamond Eye 4" turbo back system on the truck.
It's very nice. Just slightly louder and slightly lower tone, but no loud drone at cruising speed. All good!
post #8 of 9 Old 06-27-2013, 03:53 PM
I have a mbrp but have heard great things about the diamond eye...good choice. Sounds like you are happy, thats the most important part
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #9 of 9 Old 06-28-2013, 08:26 AM
Quoted: 6 Post(s)
Did you go with or without muffler?
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
