Downpipe - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-10-2013, 05:49 PM Thread Starter
Redlazer's Avatar
Downpipe
I have straight piped my oem exhaust. I'm wanting to get a downpipe for my Truck. What should I go with a 4in, 3in, or 3.5 in downpipe? I was thinking of going with diamond eye.
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #2 of 13 Old 06-10-2013, 06:11 PM
Joel's Avatar
Quoted: 10 Post(s)
Unless fitment is an issue on the early 99's there is no reason not to got with a 4"
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 13 Old 06-10-2013, 06:12 PM Thread Starter
Redlazer's Avatar
3.5in or 3in?
CAROLINA GRAY BOY
Redlazer is offline
post #4 of 13 Old 06-10-2013, 06:19 PM
Colin7.3's Avatar
Get a 4" down pipe. I have a e99 and that's what I run.
I have a full 4" straight pipe exhaust.
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #5 of 13 Old 06-10-2013, 06:21 PM
Colin7.3's Avatar
In my opinion. Straight piping a stock exhaust then putting a big down pipe on it is kinda worthless. Sure your opening it up at the turbo but as soon as you hit the stock exhaust its right back to the restrictive stock exhaust size.
Your truck your money. That's just my opinion.
Colin7.3 is offline
post #6 of 13 Old 06-10-2013, 06:26 PM
Joel's Avatar
Quoted: 10 Post(s)
I agree, but replacing a stock down pipe with 3 or 3 1/2" is just as big a waste.
Waste of time and money because the improvement will be next to nothing
Joel is offline
post #7 of 13 Old 06-10-2013, 06:35 PM Thread Starter
Redlazer's Avatar
The factory dp is flattened from the factory so I was thinking that getting a new dp that is not flattened would open it up lower egts and maybe get a little better power.
CAROLINA GRAY BOY
Redlazer is offline
post #8 of 13 Old 06-11-2013, 02:53 AM
Colin7.3's Avatar
It may help a little but then you've still got your restrictive stick exhaust pipe size. Think of it like this. You have a 3 lane highway. Well one lane is under construction. So the third lane has to merge into the other two. As we All know this causes the highway to slow down and back up. This is basically what's happening in your exhaust pipe. It may even end up hurting you cause of the restriction it could cause.
Colin7.3 is offline
post #9 of 13 Old 06-11-2013, 03:25 AM
importedaze300's Avatar
I would agree you may not see any power gains if anything I would do a whole 4" from the turbo back with a muffler delete then you will have better flow
importedaze300 is offline
post #10 of 13 Old 06-11-2013, 01:08 PM
blue99stroker's Avatar
Quoted: 277 Post(s)
the stock exhaust is 3.5 inch.
so if you can find a 3.5 downpipe you might be able to mate it to the stock exhaust fairly easy.
but a downpipe is 100 bucks. a whole kit is like 220-250.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
