any viable options for transmission? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-09-2013, 10:24 AM Thread Starter
Our 7.3 Excursion is a dedicated tow rig, and imI'm wondering if there is any transmission out there a guy could swap in the replace the stock 4speed transmission?
03 cummins - litte of this, little of that.. Tickled 700hp early 2013
monster50iii is offline
post #2 of 14 Old 06-09-2013, 10:37 AM
Joel's Avatar
Quoted: 10 Post(s)
As far as i know, the only options are a built stock unit or a ZF6 swap
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 14 Old 06-10-2013, 03:13 AM
Are you looking for greater strength or more gears as your primary goal?
You can get greater strength with a Ford "heavy duty" build of the same transmission, or with one of the aftermarket options.
You can add a second transmission after the first, to double your gear options. GearVendors has a good list of ratios with the Ford automatics, various axels, and a gear splitter.
BrownianHeatingTech is offline
post #4 of 14 Old 06-10-2013, 06:25 AM Thread Starter
Well more durability and more gears. Seems to me the 4 speed kills any towing potential and the major slipping it encounters changing gears has to be hard on the thing
post #5 of 14 Old 06-10-2013, 11:49 AM
Slipping and such may be solvable with a rebuild. Or a performance rebuild with better components and a firmer-shifting valve body, without going to the expense of a full aftermarket transmission. Depends upon what sort of demands you're making of the transmission.
post #6 of 14 Old 06-10-2013, 12:53 PM Thread Starter
The 7.3 Has the 38r turbo, intake, exhaust, and a Pheonix six position chip. What is it going to take to make the tranny reliable?
post #7 of 14 Old 06-10-2013, 01:01 PM
That's beyond me - I can just point you in the right direction.
Hopefully, someone knows what sort of torque that setup is likely to develop, and what sort of transmission can take that level of torque.
One other factor will be how many miles you have on the existing transmission. If it's relatively-new, then maybe it just needs a valvebody. If it has 200k on it, then it probably makes sense to rebuild or replace it (that's my situation - firming up the shifts would just cause something else to fail, so I'll be rebuilding it this summer or fall).
post #8 of 14 Old 06-10-2013, 01:55 PM
BTS and be done with it.
Research it, it's the real deal and there is still a waiting list so get on it as soon as you can.
Yea there are all kindsa of stage this that and the other trans out there for 450hp, I've smoked three of them before getting a BTS. They only come one way...stout!
01 F-350 reg cab srw 7.3
Important stuff:
Beans stage 1 injectors, Beans 6 position chip
Dieselsite ww2, boost fooler, wastegate controller
gauges, upgraded up pipes,
afe intake, 4" flow through muf w/turn out
BTS transmission, 6.0 cuuuler
35"toyo mt on 18" black kmc addicts
06 F-350 cc srw 6.0 lariat
build being planned...starting with the cab off
frashdog is offline
post #9 of 14 Old 06-10-2013, 02:33 PM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
X2 BTS..don't need more gears just a BTS and HP-Tq to get it done.
If you would like a quote please PM me.
Cary
CT Performance, Inc. is offline
post #10 of 14 Old 06-13-2013, 08:34 AM
timmyboy76's Avatar
depending on your location...BTS or JW (John Woods..CA) transmissions.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
