Performance upgrades. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-09-2013, 09:40 AM Thread Starter
Have about 450$ in my budget for a new upgrade. What are some good upgrades for my 2001 7.3L in that price range. Thanks in advance.
2001 7.3L Powerstroke, built trans, 6637 intake, bd billet compressor wheel, 4inch MBRP turbo back exhaust, SCT livewire tuner.
Built
Tough
Kd8324 is offline
post #2 of 7 Old 06-09-2013, 10:22 AM
Dave at BCDiesel.ca's Avatar
Quoted: 4 Post(s)
BC Diesel
Based on your signature you have installed a nice set up... maybe consider this.
Crank Case Vent Kit - may not sound like an upgrade but if you could see the restriction inside your intercooler you would think twice.
Start with the CCV kit because its in your budget, when you can replace/upgrade the Intercooler to a fresh BD Extrdued Tube Design, then replace the oil soaked intercooler boots. With a Heavy Duty Boot & Clamp Kit
Hope this helps...
Dave
Dave at BCDiesel.ca is offline
post #3 of 7 Old 06-09-2013, 11:33 AM
Joel's Avatar
Quoted: 10 Post(s)
Maybe custom tunes from PHP or DP for the SCT. That would be a good start and under budget.
It it running perfectly? I recently replaced my IPR and it felt like a performance upgrade because mine wasnt working 100% correctly
Could do IC boots if yours aren't in great shape.
HPX from riff raff?
Coolant filter and Red coolant swap?
Thats just a couple ideas
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 7 Old 06-09-2013, 11:43 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
FRx from riffraff. do you have any gauges?
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #5 of 7 Old 06-09-2013, 12:38 PM Thread Starter
Thanks,
But what does the fuel rair crossover actually do to help my performance?
and yes i do have guages.
triple pillar
pyrometer, trans temp, boost psi.
Built
Tough
Kd8324 is offline
post #6 of 7 Old 06-09-2013, 12:41 PM Thread Starter
And also i see from your sig. that you have the 6.0 cooler, I see people talk about this alot but is there actually a noticable gain, and is it just pulled straight from a 6.0 and bolt right in a 7.3 or is there a kit you need to buy?
Thanks.
Built
Tough
Kd8324 is offline
post #7 of 7 Old 06-09-2013, 12:45 PM Thread Starter
Thanks for the ideas Joel, what is the filter and red coolant swap?
Built
Tough
Kd8324 is offline
